Windows Various ESXi questions including running an Active Directory Domain Controller
Discussion in 'Software' started by Chicken76, 7 Oct 2012.
  1. Chicken76
    Chicken76 Minimodder
    10 Nov 2009
    As I understand it, for iSCSI, bonding NICs won't increase throughput, right? (unless you have each VM on a separate iSCSI target, each target with it's own IP address)
  2. saspro
    saspro IT monkey
    23 Apr 2009
    DON'T BOND iSCSI!!!!!
    Use MPIO instead.
  3. Chicken76
    10 Nov 2009
    Ehmmm... can you provide any link explaining the whys and hows?
  4. saspro
    saspro IT monkey
    23 Apr 2009
  5. saspro
    saspro IT monkey
    23 Apr 2009
  6. Chicken76
    10 Nov 2009
  7. saspro
    saspro IT monkey
    23 Apr 2009
    5.1 gives the ability for bigger datastores & smaller block sizes which is good.
    Nothing major has changed regarding configuration (I jump between v4.1, v5 & v5.1 without noticing any real changes)
  8. Chicken76
    10 Nov 2009
    OK, so NIC bonding is not a good choice for iSCSI. But is it for VM traffic?
    Say I have a machine with 4 NICs. I put 2 NICs on a separate VLAN from the rest of the network, together with the NAS-es that serve iSCSI. Would it be a good idea to bond the other 2 so that the VMs get less congestion? Or should I do MPIO on each VM too?
  9. saspro
    saspro IT monkey
    23 Apr 2009
    MPIO for iSCSI, teaming/bonding for VM traffic.
    I'm assuming you've got a managed switch connected to this then? You'll need to team/bond the ports on the switch for the VM traffic (& make them trunks) & stick the iSCSI ports in their own vlan as access ports
  10. Chicken76
    10 Nov 2009
    Yes I have a managed switch. I'll enable LACP on the ports for VM traffic, but why should I make them trunks?
  11. saspro
    saspro IT monkey
    23 Apr 2009
    If you're using multiple vlans on your VM network then they need to be trunks (you'll also need a router but that's another matter)
  12. CraigWatson
    CraigWatson Level Chuck Norris
    9 Apr 2009
    AFAIK you shouldn't need to trunk them on the switch, I've hooked up teamed NICs to non-trunked ports before and it's worked perfectly :)
    Also you can separate the VLANs on a vSwitch and get vSphere to do the routing :)
    Edit: a bit more detail. Enable VLAN tagging on your physical switch ports that the host is plugged into, then create a single vSwitch. From there, create two Virtual Machine Port Groups with the VLAN tag numbers you need, and attach the VMs to those port groups - vSphere will handle the VLAN tagging/untagging and effectively hand the VM an untagged port to its vNIC.
  13. Chicken76
    10 Nov 2009
    The bonded ports for VM traffic don't need to be part of multiple VLANs, so trunking shouldn't be necessary, right?
    Edit: Just a clarification: I don't use VLANs now, but when everything will be setup, I'm thinking of moving the NASes that handle iSCSI and the NICs that will handle iSCSI on the ESXi host to a separate VLAN to spare them of all the broadcast chatter from the main network.
  14. saspro
    saspro IT monkey
    23 Apr 2009
    You don't need trunks if you're not running multiple vlan's out to an external network.
    I always have to as I'm running environments that need it, we have combinations of multiple customers running on one setup & things like IP phones running on virtualised PBX's so vlans are compulsory for us. Therefore I always do it on training labs etc I set up as I need my engineers to be able to work on our production setups (we have our vsphere training lab connected up to our Cisco lab)
    If it's a small flat setup then you'll be fine without vlans
  15. Chicken76
    10 Nov 2009
    It will be a small business setup. One ESXi host to start, running 1 Windows Server and 1 Linux Server. Storage will be on iSCSI exclusively.
  16. saspro
    saspro IT monkey
    23 Apr 2009
    In that case make sure you've got a very good backup in place (at the esxi level).
    Personally I never use a single host on a site, always clusters.
  17. Chicken76
    10 Nov 2009
    What do you mean by "backup at ESXi level"? Backing up the .vmx vmdk etc.?
    Veeam is capable of this, isn't it? Is the ability to backup a running VM available in the free version?
    In the beginning there will be only one host, but others will follow.
  18. saspro
    saspro IT monkey
    23 Apr 2009
    Veeam is exactly what I use for backups.
    For lab use there's a free full version, if not you have to pay for the good version.
    Vmware's own backup program you can install isn't too bad for free.
  19. Chicken76
    10 Nov 2009
    Is the limited free version available for commercial use? (haven't found this specified on their site)
  20. saspro
    saspro IT monkey
    23 Apr 2009
    The free version only supports manual backup. To schedule them you need a paid for version
