News Vendors issue Meltdown, Spectre security updates
Discussion in 'Article Discussion' started by bit-tech, 5 Jan 2018.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. Otis1337
    Otis1337 aka - Ripp3r
    28 Nov 2007
    my anti-virus's are confirmed compatible, but still no update on build 1709.
    Last update was 12/12/17
  3. Pete J
    Pete J Employed scum
    28 Sep 2009
    Forgive me if I've misunderstood the exact nature of this, but does that mean all Intel benchmarks have to be revisited?
    And will this affect Otis1337's X5650? I wish I still had my 920 rig.
  4. Gareth Halfacree
    4 Dec 2007
    Yes: the Meltdown fix has anything from a zero to a 35% performance impact, depending on the workload - so any and all benchmarks should be re-run (which will also have the added bonus of figuring out exactly which workloads sit in the 0% end and which in the 35% end of the spectrum.)
    Is it an Intel x86 chip released since 1995? Then yes.
    No you don't: that's also affected by both Meltdown and Spectre.
    Seriously: every Intel x86/x86-64 processor released since 1995, bar a couple of Atoms, is vulnerable to both Meltdown and Spectre, while every other processor not specifically designed for low-power embedded use is vulnerable to Spectre and might be vulnerable to the new Variant 3a Meltdown attack too.
    Fun times!
  5. Pete J
    28 Sep 2009
    Thanks for the reply Gareth.
    Wow. This is really big. Really, really big.Time to go back to the original Pentium then - keep those pesky cyberthieves at bay.
    I still miss my 920 even if it is affected!
  6. adidan
    25 Mar 2009
    Looking forward to all those chips since 1995 being retested. Busy year ahead :)
    jb0 likes this.
  7. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
    Anyone have a large rock I can go and hide under please?
    David likes this.
  8. Gareth Halfacree
    4 Dec 2007
    Hey, I'll tell you what would be useful in the interim: run the BT benchmark suite on an Intel Windows box before and after the patch. That'll give you a baseline which you can use to guesstimate the performance impact on other Intel chips, at least, and a clear view of what tests are actually impacted.
    It won't bring up cases where the impact is significantly better or worse in different chip generations, which will only be discovered by retesting everything, but it'd be a sure-fire attention-getter if it could hit the site in the next day or so.
  9. adidan
    25 Mar 2009
    Can you test a 3770 on W7 64 please :)
    Edit: Just thought. In order to get a real impression of how it affects different chips you really should test on the MS OS available at the time too :)
    Oh and then on those available now like 7, 8 and 10 :)
    Sorry Dogbert...
  10. jaggyman
    jaggyman What's a Dremel?
    15 Jul 2010
  11. Otis1337
    28 Nov 2007
  12. RedFlames
    23 Apr 2009
    Try applying the updates manually?
    KB4058702
    KB4056892
  13. adidan
    25 Mar 2009
    W7 seemed to have one KB released today in an early monthly patch. Presume that's all there is for 7.
    Firefox got an update and IE11 updated with windows.
  14. adidan
    25 Mar 2009
    Do you have malwarebytes as well at all? I think that needs to be upto date too.
  15. RedFlames
    23 Apr 2009
    The Windows patch, regardless of whether you were on 7, 8.1 or 10 was included in the monthly Patch Tuesday patch rollup [which was pushed out early].
    FF is patched as of 57.0.4 [not sure about the ESR version],
    Chrome has a patch... incoming i think...
    Apple calim the current iOS and macOS updates include a patch for it iirc.
    Android... good luck...
  16. adidan
    25 Mar 2009
    I think I read something about Chrome being on 23rd? Seems a bit of a wait if that's the case but I think that's when the next update was due anyway? Not sure on that one.
    And what of AI? Is that in trouble? Are we going to have the flawed AI overlords come and use us as walking batteries?!?
  17. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    [SMUG PIXEL NOISES]
  18. Pookeyhead
    30 Jan 2004
    Seems pointless upgrading my PC now then.... Surely any future chips released will be a revised design... the sensible thing to do would be to just hang on until then.
  19. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    You're going to have a long wait for Intel to revise their design as the Meltdown flaw has been part of their chips for over two decades and an underused mitigation to that flaw has been included for the past six odd years but has largely been ignored by software developers.
    Spectre on the other hand is really only something that can be mitigated via software updates, at least that's my laymens understanding of the situation.
  20. Guest-44432
    Guest-44432 Guest
    Intel has a detection tool to see if you're vulnerable, and whether you need a firmware update.
    https://downloadcenter.intel.com/download/27150?v=t
    Also I ran Passmark benchmark to see if there is much of a performance loss since the windows patch updates, which seems like there isn't CPU score before the patch 9261, after 9255
    https://www.passmark.com/products/pt.htm
    This site was a good read on how to help protect yourselves.
    https://www.pcworld.com/article/324...otect-your-pc-meltdown-spectre-cpu-flaws.html
    I was planning on upgrading to the 8700k this month, but think I will hang fire, as my aging 4670K @4.2GHz is as fast as a 7600K in games. So hopefully Intel will fix the issues in the next die shrink.
Tags: Add Tags
