News VESA unveils DisplayPort 2.0
Discussion in 'Article Discussion' started by bit-tech, 27 Jun 2019.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. Anfield
    Anfield Multimodder
    15 Jan 2010
    4K 144hz, 3440x1440 200hz, 3840x1600 175hz monitors are already available or due shortly and all of them desperately need DP2.0, so pretty disappointing to see it being still 1.5 years away...
  3. wolfticket
    19 Apr 2008
    It would be nice if it could carry some power. Low power monitors that only require a single connection would be cool (without needing to faff about with USB).
  4. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    Inheriting the Thunderbolt 3 interface (and Type C port capability) you can supply power over the same connector. You need to use Type-C rather than the old DP/mini-DP connectors as those lack power pins and existing cables are not rated for current carrying capacity.
    Biggest disappointment is continuing to kick the optical transport can down the road. Bulk fibre is cheap but endpoints (optical transceiver modules) are not due to relatively low volumes and premium target markets. Standardising a widespread interface on optical would have the effect of opening up a bulk market for optical transceivers and pushing price down to match or beat that of the active channel conditioners needed for high bandwidth copper interconnects.
  5. monty-pup
    monty-pup Minimodder
    8 Apr 2018
    Thank you for the heads-up on that 3840x1600 175hz monitor. I googled that res and hz and came up with this:
    LG 38GL950G 38 inch Ultragear Nano IPS 1ms Curved Gaming Monitor w/G-Sync
    Unless something better is coming, that’s my next monitor! Cheers!
Tags: Add Tags
