Alllllllllllright.. So I got my VFD and had my Lian Li and thought "mmh, using the usual faceplates of course sucks. Make yer own ffs!" And that's what I did, made my own faceplate for the VFD. Here you go (pictures are hosted on port 1027 so enable that port if necessary): Like it? Here for the people that can't enable the port 1027. This is only tempoary: http://www.tweakersguide.de/images/vfd1.jpg http://www.tweakersguide.de/images/vfd2.jpg
Oh I forgot: This is not blooooo at all. The cam made it look bloo. But I will soon add the bloo filter and then make some "sunlight-shots".
Industrial lookin with the screw-heads showing But by far better than the standard stuff that's available.
Nice work! Ive got a VFD mount coming up very soon, when I can get my hands on a line bender (of the plastic type)
Very nice, I was wondering exaclty how you had done that, and if both of the bays on either side are still useable. I have ordered a VFD and plan on doing to wiht my Lian Li PC 60 I have been busy working on my info/lightcenter... (ill post an explanation later). I was wondering you could send me a explanation I_am_TwiSteD_LoGic@hotmail.com Thanks alot [edit: fixed email link ]
Hi, Thanks for your comments. I unfortunately do not know what you mean at all. Try to explain it a bit better, I'll of course try to help
Twisted - take a look here This is my VFD, and I have piccies showing how it's mounted etc. Should give you some ideas on how to do your own. Firewars - aren't VFD brilliant! Needs some blue gel sheet though
Yeah they rock I'm gonna make the "hole" for it bigger though. It's too small And I will add the bloo filter
mmmmmmmm i wanna make a box for mine no -- it has to be hard tho, so i bang ppl round the head with it @ lan parties
