Displays VGA to HDMI?
Discussion in 'Hardware' started by silk186, 18 Jun 2019.
  1. silk186
    silk186 Derp
    1 Dec 2014
    My new monitor only supports HDMI. I want to connect my HPE server which only supports VGA to the monitor. I have a VGA to VGA cable. I also order a cheap VGA to HDMI cable on eBay which didn't work. What do I need to connect the two and how cheaply can I do it for? I would be happy to buy something used.
  2. Anfield
    Anfield Multimodder
    15 Jan 2010
    That is hdmi to vga, not the other way round.
    vga to hdmi:
    https://www.amazon.co.uk/dp/B00K808RVQ
    However if there is any way at all to fit a GPU in the server, I'd just buy something like a used Geforce 730 or similar (they can be found on the bay of flea tor basically the same price as the adapter I linked to).
  3. faugusztin
    11 Aug 2008
  4. sandys
    sandys Multimodder
    26 Mar 2006
    Can you not just remote desktop to server or telnet?
