News VIA announces APC Rock, Paper
Discussion in 'Article Discussion' started by Gareth Halfacree, 17 Jan 2013.
  1. Gareth Halfacree
    4 Dec 2007
  2. Bloodburgers
    Bloodburgers Minimodder
    30 Apr 2009
    Any deatails on the APC Scissors?
  3. devilxc
    devilxc Biding my time...
    23 Mar 2010
    ...APC Lizard...APC Spock?
  4. Jimbob
    Jimbob Minimodder
    2 Jul 2009
    Or you could just buy a Raspberry pi.
  5. Gareth Halfacree
    4 Dec 2007
    Trouble with the Raspberry Pi is it's ARMv6 - which the APC 8750 was, too. The APC Rock, APC Paper (and the wonderful open-source Olimex A13-OLinuXino) are Cortex-class ARMv7 devices - which makes them significantly more powerful than the Pi. It also means they can run software the Pi cannot: there's still no workable build of Android for the Pi, nor can it run any version of Ubuntu newer than 9.04 - both software packages that work fine on Cortex-class processors.
    Basically, if you don't care about performance or compatibility and you're on a budget, buy a Pi; otherwise, hold out for a Cortex-class chip.
  6. schmidtbag
    schmidtbag What's a Dremel?
    30 Jul 2010
    MK802II is a much better choice than Raspberry Pi and costs the same, and odroid-U is a better value than both. RPi is kinda obsolete these days considering there are better-valued products out there or just simply more useful ones.
  7. Psyance
    Psyance What's a Dremel?
    6 Dec 2012
    Hehe, gotta love TBBT :D
  8. adidan
    25 Mar 2009
    Delete
