Portable Video converting for iPod not working
Discussion in 'Hardware' started by Tomm, 11 Jan 2008.
  1. Tomm
    Tomm I also ride trials :¬)
    12 Apr 2004
    Any suggestions for the best app to encode a DVD to iPod format?
    I've been trying to convert a DVD to stick on my iPod (5g, 30Gb if it makes a difference), and so far I've used Handbrake for both Mac and Windows (The Windows machine doing it substantially faster, but then it is more powerful). But although both produced results that work fine on the iTunes and VLC, iTunes refuses to copy either of them to my iPod, so I'm guessing they're somehow in the wrong format?
    Next option is to re-encode the video using either Super or Videora for PC, or iSquint for Mac. I quite like Super so I'd like to give that a try - can anyone point me to a website with the optimum settings for conversion?
    Can anyone guarantee a method that will work?
  2. eddieitman
    eddieitman What's a Dremel?
    11 Jan 2008
    I have always liked an application called SUPER in windows does everything a little difficult to find the download link on there site, just google super
    Also pocket divx encoder is good
    both free
  3. TTmodder
    TTmodder Hammertime
    9 Apr 2005
    Just a little note. Super is still in development so some formats would cause it to freeze upon converting. For an example i cant convert *.flv files to any other format.
  4. eddieitman
    11 Jan 2008
    I have used super and been able to convert FLV files to avi, wmv maybe something with the codecs on your machine.
    I also have FLV player installed maybe thats what you need
  5. bennifer
    bennifer What's a Dremel?
    26 May 2004
    When ive got a movie saved in an avi format I just load it in quicktime and do an export in ipod format. it handles it all for me. just add to itunes movie list and it syncs.
  6. Tomm
    12 Apr 2004
    Maybe I didn't explain properly. The video converts fine - when when I go to copy it to the iPod it just won't copy.
    You need QT Pro for that Bennifer? I'd rather a PC app but I'll try that
  7. spectre456
    spectre456 What's a Dremel?
    29 Dec 2007
    i use the videora video converter for my touch. it's got settings for the classic/5G ipod video. videora is cabable of handling DVD file formats. all you need is to rip the dvd with some dvd ripping software then simply convert it to the H.234 (or whatever format you use). itunes is not very good for movie conversions. it takes forever and sometimes when i do it there is no audio playback at all.
    hope that helps
  8. dragontail
    dragontail 5bet Bluffer
    9 Jun 2005
    SUPER +1
  9. heir flick
    heir flick Minimodder
    2 Feb 2007
  10. eeevan
    eeevan Dremel Master
    21 Oct 2007
  11. manjowithane
    manjowithane What's a Dremel?
    14 Jan 2008
    I have used Handbrake on Mac to convert videos into iPod format and it copies fine to my iPod. The only time iTunes has refused to copy it onto my iPod for me, was when I tried to make it into a 'tv show' and for certain converted files it would corrupt it.
