Windows Video/data recovery
Discussion in 'Software' started by DeanSUNIAIU, 1 Nov 2023.
  1. DeanSUNIAIU
    DeanSUNIAIU Modder
    11 Aug 2021
    Other half accidently deleted a video mp4 file from SD card, looking for a free windows based solution to recover the data.
    It's a minefield of bloatware and paywalled garbage out there.
    Thank you
  2. kenco_uk
    28 Nov 2003
    Photorec has done the job for me in the past. Despite the name, it picks up literally anything. Be mindful (unless it's changed) the filename and file extension may not be restored and it might look like a load of gibberish files, but as long as the sdcard hasn't been used since accidental deletion of the file, it should pick up the file in need, it'll just need renaming after. Oh, and it will take some time for it to run through, so I guess set it going after making sure the computer you're running it on won't go to sleep.
    DeanSUNIAIU likes this.
  3. DeanSUNIAIU
    DeanSUNIAIU Modder
    11 Aug 2021
    Will get it a go, thank you.
  4. ModSquid
    ModSquid Multimodder
    16 Apr 2011
    Failing the above, Recuva from Piriform has been useful in the past (plus I had some others saved down somewhere as I had to do a bit of the same once, I'll see what names I can dig out once I have the machine reinstalled and running again).
  5. Shirty
    18 Apr 1982
    +1 for Photorec. Never failed me. It might only have a basic DOS-style interface but it's pretty quick and it just works™
  6. DeanSUNIAIU
    DeanSUNIAIU Modder
    11 Aug 2021
    I did download that Recuva but wanted something like £80 for a years license.
  7. ModSquid
    16 Apr 2011
    Really?! Blimey. Was free last time I used it.
    Apologies for landing you a red herring in that case.
    EDIT: No, there's definitely a free version. Even the Pro version is only £25, difference being it supports virtual drives or some bits. I'm on my phone at the moment and signal is poor for uploading screenshots, but I'll try and grab one later. I just searched for "piriform recuva" and went to the top link, which is now on the renamed ccleaner site. Had free version on first page.
    DeanSUNIAIU and Arboreal like this.
