This is my first case that I present here, this time will be a case to stay at the headquarters of CoolerMaster Brazil. I was selected on the team to make the case until next month. I chose the Viking theme and made some appliques using leather. The case will be the MasterCase 5 Pro And one of the images I used as a base I hope the weekend has come a long way.
Follow the new updates, on the right side I will add a shield. Still defining what will be the painting of the same and finish for the environment of the shield. I bought the woods in a reasonable size to work with. And the result of the initial assembly. I used this time zinc plates used in gutter to prepare the cover and the front of the case that will receive a leather applique. And for the inner cover and the front, I bought a calf leather. And to give some more details, I created an applique that will be glued in the front and the top of the case. And another update midweek, my wife got the details on the laser, and the person of the cut erred in not validating the mirroring and cut two equal pieces, there I go have to go complain, explain and find a solution to the problems . However, there is the result: Olhando pessoalmente o efeito é maior e diferença de cor é mais perceptível. Update of the shield assembly: And I have problems with how to attach and how to make the cable for the ax:
