Networks Virgin Media's "Hub" - Useless crap....
Discussion in 'Hardware' started by mrbungle, 29 Oct 2010.
  1. mrbungle
    20 Sep 2004
    I have recently had 20mb optic installed, all dandy.
    Except that the wireless hub they have built into the modem router is utter rubbish.
    I have a smallish flat and it wont get a reliable signal anything past the sofa in the front room. Past that signal drops all the time. Changed the channel and security settings and its still a bag of spanners.
    Is there a way to set it up so i can daisy chain my old router onto it to use that as it gets a perfect signal?
    Any ideas would be great, don't really want to have to call asia to talk to virgins inept customer services.
  2. bulldogjeff
    2 Mar 2010
    Disable the DHCP and set it to run like a network bridge.
  3. mrbungle
    20 Sep 2004
    im a plug and go kind of guy with networks....
    is disable dhcp all id need to do?
  4. Phalanx
    Phalanx Needs more dragons and stuff.
    28 Apr 2010
    Do Virgin allow you to put in your own router? If so, that's an option. I did that with my BE package.
  5. saspro
    saspro IT monkey
    23 Apr 2009
    You have to use their modem but you can tag a router to it
  6. Phalanx
    28 Apr 2010
    Basically, disable DHCP on the Virgin router, plug in your own router and configure that one as the DHCP.
  7. mrbungle
    20 Sep 2004
    Thats just the thing new customers dont get a standalone modem
    you get some god awful cable modem router by netgear and its laughable with wireless.
  8. saspro
    saspro IT monkey
    23 Apr 2009
    In that case, turn it in to a bridge and use your own router
  9. Zoon
    Zoon Hunting Wabbits since the 80s
    12 Mar 2001
    The way I'd go is:
    1. On your old router, disable DHCP and change the IP address to .2 in whatever range the new one users.
    2. Plug them together by LAN cable.
    3. Disable Wifi on your new router.
    4. Edit the DHCP pool on your new router so it doesn't try and give out .2 in your address range.
    5. Profit.
  10. adam_bagpuss
    24 Apr 2009
    personally id go with faulty router or busy wi-fi channel as i have the same one and it function just fine.
    the missus can use the laptop downstairs and opposite side of the house with no issues.
    my wii in the same place conencts fine too.
    have no issues with my phone or her phone either anywhere in the house.
    my house is very old (1896) and so has solid walls everwhere.
  11. wyx087
    wyx087 Multimodder
    15 Aug 2007
    ask for an engineer.
    i managed to get an engineer to my place, and complained to him about the bad Virgin hub. he went to his van and pulled out two old styled cable modems for me to choose from.
    using model with my Linksys WRT320N gigabit wireless-N router perfectly fine.
  12. DarrenH
    DarrenH What's a Dremel?
    12 May 2010
    I have the 300Mbps Netgear wifi Router with my virgin and it works just fine. The only problem is with older devices that are not n+ compliant. So I just tagged my old wifi router to the new one and hey presto all the older devices still work a treat at the same time as the newer ones.
  13. lysaer
    lysaer Suck my unit! Kirk lazarus (2008)
    15 May 2010
    Are there a lot of incredibly thick walls between the router location and the front room ?
    My mate's flat was a refurbished council flat, this thing was built like a brick s^%t house, insanely thick walls etc, we tried a variety of routers and the signal could just not get through them.
    In the end we just used a repeater in another room to get the signal from the bedroom to the front room. You should be able to do the same thing with your old router, what model/brand is your old router ?
  14. legendzarr
    legendzarr What's a Dremel?
    30 Dec 2011
    internet ran at 800kb/s, i complained a coulpe times and the speed suddenly increased by a couple megabytes, hmm
  15. jizwizard
    jizwizard Modder
    24 Dec 2010
    holy thread revival
  16. sniperdude
    sniperdude Minimodder
    8 Sep 2010
  17. Harlequin
    Harlequin Modder
    4 Jun 2004
    I think mr bungle may have fixed this 2 YEARS ago
  18. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    Their super hub is useless via the wireless
  19. mrbungle
    20 Sep 2004
    Touchwood after around 6 months this fixed itself, I guess through a firmware update.
    Not amazing but wireless has been fine for the last 18 months or so.
  20. jizwizard
    jizwizard Modder
    24 Dec 2010
    I have the same hub and my wire less improved dramatically when I changed the channel of the wireless to 11. Seems mine was fighting with every other Netgear in the street
