Networks Virgin Router (upgrade options)?
Discussion in 'Hardware' started by penryn 2 hertz, 7 Aug 2020.
  1. penryn 2 hertz
    penryn 2 hertz I'm not a science fiction writer...
    10 Jun 2010
    Hello everyone.
    I have a virgin super Hub 3 and experiencing terrible wireless issues with phones and laptops.
    The connection is very intermittent drop out and disconnections constantly.
    I have called virgin several times about this issue and all they say is I've run tests on your superhub and everything is OK.
    I also get the following responses from there technical support saying as long as I get a solid connection through ethernet ports directly then it's OK.
    Also apparently wireless connection issues aren't covered by there service .
    I would like to put the hub in modem mode and use a 3rd party Wireless Router are there any good choices???.
    I have a budget of under £100 and would like a usb 3.0 port for storage on the network as I own a 4tb 3.0 external hard drive for backup files.
    You're help would be very much appreciated .
  2. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    Asus. Not had a single issue with mine and i've had it years.
  3. cobalt6700
    cobalt6700 Minimodder
    17 Oct 2005
    I have an AC68U running Merlin for the last couple of years - great so far :thumb:
  4. Sentinel-R1
    Sentinel-R1 Chaircrew
    13 Oct 2010
    Go Ubiquiti and don't look back. Not the cheapest solution but expandable, totally configurable and it'll just work well.
    Edit - nvm. Just saw your budget limitations. Worth bearing in mind though if you have a desire to upgrade in the future.
  5. silk186
    silk186 Derp
    1 Dec 2014
    Is this a new issue? I've had this issue (not WiFi related) since lockdown with a 200M plan. I use a tp-link wireless router.
