Other Virus -- FIXED -- WINNER
Discussion in 'Tech Support' started by Burnout21, 7 Jul 2012.
  1. azrael-
    azrael- I'm special...
    18 May 2008
    Where does that file come from?
  2. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    aramil supplied it in this post
  3. azrael-
    18 May 2008
    I think you should use the files from the DOS Flash folder of SP57421. Just copy everything to a bootable USB drive substituting the J01_0221.BIN file with your modified BIOS image (I suppose the HP 6200 supports bootable USB drives).
  4. Burnout21
    9 Sep 2005
    Do you think i'll get verification issues?
    Edit, exactly the problem, the Dosflash app
  5. azrael-
    18 May 2008
    No, since DOSFlash doesn't use the .sig file and MMTool will have applied a valid checksum to the modified BIOS image.
  6. Burnout21
    9 Sep 2005
    Its something to do with the flashuefi.cpu (possibly)
  7. azrael-
    18 May 2008
    Flashuefi.cpu seems to be an UEFI application. I've no idea if it contains any additional checks. Does it throw a fit?
  8. Burnout21
    9 Sep 2005
    Well first it points out the bios revision numbers are the same, (asks if i want to continue)
    Then is mentions flashuefi.cpu version being the same (ask if i want to continue)
    Uploads to 100%
    then reads
    Error! System Rom image is invaild
  9. aramil
    aramil One does not simply upgrade Forums
    10 Jul 2012
  10. Burnout21
    9 Sep 2005
    Direction of investigation may have taken a new route away from the Bios/firmware, shall report back soon
  11. Burnout21
    9 Sep 2005
    So the new direction I went in was to use the ATA-secure erase tools built into the firmware of the Hard drive, in hope of removing any HPA partitions that it could be hiding in. Apparently DBAN can miss these.
    Anyway, still got the same issue of the white screen. Feeling pretty rough today with a sore throat so not 100% behind it at the moment.
    Going to re-install and enable remote access to see if I can actually get anywhere with it after infection.
  12. aramil
    10 Jul 2012
    I hope you feel better soon. health before tech :)
  13. Burnout21
    9 Sep 2005
    So, I installed a spare network card that I knew windows would have drivers for.
    Installed Win7, whilst that was installing I download Comodo Internet Security to a flash drive. The instant Win7 was up, I installed Comodo and then gave the machine a physical network connection to allow Comodo to update.
    From there the machine had a decent Firewall in place, on the 2nd reboot it stopped rcpnetp from dialling out. All Windows updates installed, and its been up for 4 hours with out headache.
    Pliqu3011, Carrie and sp4nky like this.
  14. azrael-
    18 May 2008
    Well, that's a solution of sorts. :)
    What about the spare HDD?
    BTW, hope you're feeling better.
  15. sp4nky
    sp4nky BF3: Aardfrith WoT: McGubbins
    15 Jul 2009
    Well done! 10/10 for perserverance. How much is this going to cost the customer?
  16. Burnout21
    9 Sep 2005
    Feel like utter ****. With regards to the spare HDD I was going to test, I doubt it would resolve the problem as many people have tried the same. If the infection did create its own HPA, or if the computrace creates a HPA then I would be stuck with two drives being a pain in the backside.
    Zero, well maybe a beer..
  17. aramil
    10 Jul 2012
    A well earned beer
    Sent on my CM10 JB powered i9100 by TapaTalk 2
  18. DeafGamer2015
    DeafGamer2015 Minimodder
    5 Jun 2010
    I'm a bit curious on Comodo Internet Security.. is it reliable?? just want to know..
  19. Shirty
    18 Apr 1982
    I use Comodo firewall. It's fine, and has got me out of a few annoying problems in the past.
  20. Burnout21
    9 Sep 2005
    Considering it's the only product offered online that has actually stopped this problem, yeah I would considered them reliable.
    Teelzebub likes this.
