Vista and Overclocking
Discussion in 'Hardware' started by cannon, 12 Mar 2007.
  1. cannon
    cannon What's a Dremel?
    15 Jan 2004
    Hi all,
    Had my system overclocked as per my sig. But I couldnt install vista, so I turned it off and it worked.
    I have tested it to see how far or if I can push it again and was wondering if anyone had had any success with it? Is it pushing the memory that it doesnt like or what?
    Cheers
    Paul
  2. Bluephoenix
    Bluephoenix Spoon? What spoon?
    3 Dec 2006
    I ran into some weird scenarios when first building my rig (see sig)
    and had OC'd the RAM, GFX, and CPU to their current levels, but when I try to install vista ultimate 64.......... nothing.
    I turned off the OC settings (after noting them) and tried to install again, and went without a hitch.
    Once it was installed I restored the OC settings and haven't had an issue since.
    I still would like to know what caused that :confused:
  3. cannon
    15 Jan 2004
    hmm - i might crank mine back up and see how we go :) keep you posted
  4. DougEdey
    5 Jul 2005
    Vista is a lot less forgiving then XP, because it uses more of the RAM at any point in time it will invariably find those modules which cannot withstand the FSB you placed upon them so it will die.
  5. Bluephoenix
    3 Dec 2006
    true, but this also means you get a better measure of whether the RAM can actually handle the speeds. So it seems like a good thing to me.
