Vista type/key problems
Discussion in 'Tech Support' started by scq, 2 Jun 2007.
  1. scq
    scq What's a Dremel?
    4 Mar 2005
    Anybody experience this, that once in awhile, letters on your keyboard, like "?/[]" etc, turn up as accented letters?
    I often get ? = É
    This is often remedied by restarting the symptomatic application, but any ideas why this happens?
  2. BioSniper
    BioSniper Minimodder
    5 Feb 2002
    Ééééééééétttt sounds liké your kéyboard is méssÉd up :p
    [/stops being stupid]
    Have you tried disabling sticky keys in the accessibility options (that's if Vista even has it, I've not checked)? Just thinking that it could possibly be a key modifier being stuck to on causing such happenings and may characters have CTRL+ALT+SHIFT modifiers. If sticky keys is on for what ever reason then it could be modifiers being activated.
    Also as always do a spyware scan, anti-virus that kind of thing as it could always possibly be some nasty piece of software in the background causing it too.
  3. Mighty Yoshimi
    Mighty Yoshimi Motormouth
    4 Sep 2006
    Did you get vista on disc or did you download it and burn it.
    Cause im at uni and part of something like the msdnaa alliance thing, i got it for free downloaded it and burnt it, and it did stupid stuff like that when i burnt the disc at 4* speed, so i had to put it slower still (1*) so it didn't mess up.
    Something to consider, however the keyboard seems to be more likely
  4. beesbees
    beesbees What's a Dremel?
    29 Apr 2007
    What keyboard layout did you choose right at the beginning of installation?
  5. scq
    4 Mar 2005
    Maybe it's just coincidence, but I got my copy off MSDNAA as well, though I forgot how I burned the discs. They didn't mess up though.
  6. DougEdey
    5 Jul 2005
    Check sticky keys, sound like you left them on,.
  7. scq
    4 Mar 2005
    Checked. It's all disabled.
  8. Amon
    Amon inch-perfect
    1 Jun 2007
    I'm guessing you're using a laptop; namely, IBM/Lenovo. We seem to always suddenly get this when typing, and it's disastrous during meetings and presentations :duh:
  9. scq
    4 Mar 2005
    I'm actually using a self-built PC. I know others also get this problem.
  10. monkeybone
    monkeybone What's a Dremel?
    28 Jan 2005
    This is usually due to the language of your system. If you hit shift+alt or something like that, it will change the keyboard language. You may want to check in your languages (regional and languages settings) to either remove french (or any other language not being used) so that only english appears. This may be the case...
