Electronics Voltage halving? Maybe?
Discussion in 'Modding' started by veland, 19 Feb 2005.
  1. veland
    veland What's a Dremel?
    2 Feb 2003
    I'm modding my printer (why not!)
    So, I need to get some +12V in there.. The only problem is that when the printer sits idle, the PSU delivers 12V. But as soon as somethings starts happening, it jumps to 24V.
    Ok, dropping 24V to 12V is not hard, I could just throw in an LM317 with the right resistors. But what would then happen when the supply voltage drops to 12V? The specs say LM317 should have 1,5V higher supply then draw. Would the output just drop to 10,5V?
    A bit lower than 12V when in idle is ok, so other great ideas? Just mentioned the 317's since I've got some laying around here...
  2. nick01
    nick01 What's a Dremel?
    6 Nov 2004
  3. veland
    2 Feb 2003
    Looked at those, but that pricetag is WAY too much..
    So I assembled a litte LM317 based regulator, it gives me about 11V when supplied with 24V and about 10V when supplied with 12V.
    Works fine, and the printer is still alive!
