Windows W7/64 update problems after W7 re-install
Discussion in 'Software' started by neil_b, 2 Oct 2014.
  1. neil_b
    neil_b Minimodder
    20 Jun 2009
    I re-installed W7/64 over the weekend and initially everything seemed ok, however there’s an issue with the W7 re-install, in that the re-installed W7 will let me do most updates but WON’T let me install W7/SP1 and keeps giving error code 8024200D consistently each time.
    I’ve tried downloading the Windows Update Readiness tool that MS recommend in this situation, re-booted but no difference.
    It was suggested to run Microsoft Fix-it, but not only didn’t that do the trick but after a reboot, Windows now can’t seem to even DOWNLOAD the W7 SP1 let alone run it. Getting concerned about this and would welcome any advice – I really DON’T want to have re-install W7 again if I can avoid it.
    Thanks.
  2. neil_b
    neil_b Minimodder
    20 Jun 2009
    I've now run the MS-recommended sfc /scannow command and a full scan says "Windows Resource Protection did not find any integrity violations, and I still can't get the W7 SP1 to install. Joking apart, can I manage without the SP1 update?
    Any ideas?
  3. Big Elf
    23 Apr 2009
    I had a very similar problem last week except it was 2 updates that refused to install no matter what I did. I ended up reinstalling again and all the updates installed without problems.
  4. T2I3M
    T2I3M Minimodder
    13 Mar 2010
    Ive had this happen before, the only fix i found to work was a reinstall.
  5. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Can you not download the sp1 iso on another pc/laptop?
    I had the same issue and an SP1 disc fixed it.
  6. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    ^^^^^^this^^^^^
  7. damien c
    damien c Mad FPS Gamer
    31 Aug 2010
    I have previously had issues like this on Windows 7 and Windows 8 and generally I found that running the Microsoft Fixit tool found the issue, and then fixed it and after a reboot I was able to install the updates.
    Just make sure before running it that the time and date are correct, as for some reason that seems to affect it as well.
