Hi. I am still planning my mod and want to get me case drawn up properly. What I am looking for is a collection of cases so I can take out mounting holes etc and maybe a couple of good ideas out of cases and cross check them with some other so I know I have a accurate drawing to work off of instead of spending hours measuring the computer I need to use to draw it. I am not going to copy your whole design I already have a layout etc just saving time so dont worry. Thanks heaps.
I have a mATX mobo-tray drawn in AutoCAD 2008. How detailed to you want it? Do you also want markings for IO-shield included? I can whip up a ATX if you want.
Hey. I need everything in a case. Some I can draw myself but if you have an entire case that to could send me it would be a lot easier for both of us. Otherwise yes I need arc and I need to make the io thing on the back of the case as well as the gpu holders whatever you call them. I need them detailed enough to get it Cnc and everything fits on. Thanks heaps.
I don't have an entire case, but I can send you a complete mobotray made from the ATX spec. I can also send you a motherboard ? Whatever you want pal.
Atx please. Evga x58 classified 3x sli is standard Atx right? I remember reading that it has the same mounting just sticks out more. Thanks.
