Wanting to build 64bit system - help needed
Discussion in 'Hardware' started by keir, 31 Jul 2004.
  1. keir
    keir S p i t F i r e
    5 Oct 2003
    Hi I'm wanting to build a 64Bit system
    I've tried looking into it myself but it just confused me lol.
    I'd like to know what mother board is good and want CPU would be good for it.
    Im going to get a Sapphire Radeon X800 XT, so 8X AGP is a must.
    I'm looking at cpu of at least 2.4Ghz and im Planning to water cool it so overclocking is an option I'd look into.
    The price's wont bother me just let but I dont really wanna see a motherboard that cost's something stupid like £200.
    Edit - Im now thinking about a mobo with PCI express
  2. Slink
    Slink B7
    7 Oct 2001
    Hey bud,
    Im in the same boat (and same town :p),
    Im considering a MSI K8T Neo-FIS2R which is socket 754
    coupled with a 3200, As far as im aware its compatible, but like I say, im new to AMD also being a pentium fan!
  3. Foster
    Foster What's a Dremel?
    18 Jul 2004
    If you meant an actual 2.4 GHz frequency then you've only got one choice, the Athlon 64 FX53 (oh mama!). With this chip I'd recommend the MSI K8N Neo2 board. Now if you were just looking for P4 2.4 GHz performance I'd say your safe with any of the AMD 64 chips. If you go with a 754 socket chip, I'd recommend the Neo in place of the Neo2
  4. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    754 and the 3700 are an unbeatable combination, there have been some great results from that combo. IIRC the Epox is one of if not the best 754 mobo.
  5. Mosha
    Mosha What's a Dremel?
    31 Jul 2004
    What I would suggest is:
    MSI K8N Neo Platinum
    and a
    3200+
    Get some decent cooling, some decent ram and overclock a bit and you save yourself money :clap:
    No budget at all or is there?
  6. Tolsk
    Tolsk What's a Dremel?
    14 Jul 2004
  7. keir
    5 Oct 2003
    This is what I've found so far, from overclockers UK site, and the AMD Athlon64 3200 from aria.co.uk:
    Code:
    ---------------------------- CPU ---------------------------------------------
    AMD Athlon 64 3700 (Socket 754) - Retail (CP-087-AM)               -  £367
    AMD Athlon64 3200 RET (AMD Socket 754)                                -  £145
    --------------------------- MotherBoard --------------------------------------
    MSI K8N Platinum nForce3 250 (Socket 754) Motherboard (MB-022-MS)  -  £82
    ---------------------------- RAM ---------------------------------------------
    Corsair 1GB DDR XMS3200C2 Pro TwinX (2x512MB) CAS2 (MY-026-CS)     -  £210
    Theres a masive differce in price on them CPU's what is the default speed of the AMD Athlon64 3200?
    I hope it isnt 1.9Ghz like this
  8. Perpetual Notion
    Perpetual Notion What's a Dremel?
    28 Jan 2004
    I've got a MSI K8 Neo Platinum mainboard with an Althon64 3400+ and PC3200, it's a great combo performance-wise but I'm warning you. For the life of me, I can't get Windows XP Pro to work. I've had to use 2000 to get it up and running.
  9. Mosha
    31 Jul 2004
    3200+ is clocked at 2.2Ghz
    And if there isnt a budget then for cooling get something like:
    Asetek Vapochill Lightspeed
    GPU:
    Sapphire X800 Pro Toxic (overclocks beyond XT PE speeds, and again you save yourself money :D )
    Hard drive:
    2x WD 36.7 Gb in Raid 0
    2x Seagate Barracude 7200.7 200Gb
    Case:
    Lian-Li PC60
    Ram:
    OCZ Platinum Limited Edition 2x512
    (If you can't find this then get some of that corsair
    DVD CD/Rom drive:
    Find a good one yourself ;-)
    Powersupply:
    Antec TruePower
    CPU:
    3200 1Mb cache (make sure its 1meg)
    Motherboard:
    Soundcard:
    Creative Audigy2
    etc, etc
    Anything else you need just ask!
    Oh and these are only my suggest, you could change these things if you dont like em :thumb:
  10. keir
    5 Oct 2003
    ok can someone tell me where I can get a 3200+ or 3400+ with 1mb cache :)
    I've been looking on aria.co.uk but they dont seem to do 1meg :eyebrow:
  11. thierryhenry83
    thierryhenry83 What's a Dremel?
    5 Aug 2004
    Keir there is not a noticable difference between the two.
  12. keir
    5 Oct 2003
    my current set up
    athlon xp 2700+ (333FSB) (2.1Ghz)
    1GB DDR 333
    Will I even notice a perforance differance?
  13. dead_man
    dead_man Confucious say: WTF???
    4 May 2004
    that pic is a fake, yea it says 1.9ghz but where the CPU is meant to be said there nuttin
  14. tmod
    tmod What's a Dremel?
    9 Apr 2004
    There are 4 AMDs with a frequency of 2.4 GHz...two for socket 754 ( Newcastle 3400+, 3700+), two for socket 939 (3800+, FX-53). In both cases, the difference between the two processors is cache size. The FX-53, however, has an unlocked multiplier, making it more OC friendly. The 3400+ is by far the cheapest; usually <65% of the price of the others.
  15. keir
    5 Oct 2003
    So what Do you people think then?
    tbh i think £500+ just for a CPU is stupid. Is it worth getting a 64 bit system?
  16. keir
    5 Oct 2003
    Im now thinking about a mobo with PCI express on it, so im off to look at some more mobos now, still need to know if its worth getting this stuff. :blah:
  17. DanMcr
    DanMcr What's a Dremel?
    27 Jul 2004
    Go with socket 939 not 754.
    The athlon 3500+ can be had for about £230. Asus and Abit already have K8T800 boards out, and more are on the way with nforce chipsets and PCI-E. Should be out within the next month or 2 i would have thought.
  18. keir
    5 Oct 2003
    Think im just going to wait till christmas time then.
  19. ICDragon
    ICDragon What's a Dremel?
    25 Jul 2004
    I agree... get a socket 939 but get a 3800+... they outperform even the 3.4 EE in many cases. Also the prices have been going down vary fast, and it supports dual channel DDR which the socket 754s don't. If you go with that I would suggest a Gigabyte nForce 3 Ultra board (kinda pricy but worth it) or a K8T800 Pro Asus... both are great boards and support AGP
    as for socket 754, the 3700+ is great, but not owth it if you have enough for a 3800+, which will indeed make a huge performance difference over your current system
    On a side note, I really don't think that PCI-Express is really worth the wait, especially since then best cards arn't even out yet, and may not be for a while. Even still I really don't think that It will make much difference anyways in game and such.
  20. DanMcr
    27 Jul 2004
    Yea, id get the 3800 if i could afford it, but the 3500 is tempting. Its half the price, and with decent watercooling it should be possible to get 2.4ghz out of it. So you would have a 3800 (which is exactly the same as the fx53 except the cache, but it can more than hold its own with it) for about £230. :D
    I cant see it being too long before there are 939 3600's an stuff. They might just do a 3500 with 1mb cache for it or something. Then the o/c would be really fun. (This is all speculation of course :D)
