Planning Water cooled modem/router
Discussion in 'Modding' started by dark_avenger, 3 Nov 2011.
  1. Livio
    Livio What's a Dremel?
    20 Sep 2011
    Why do you bother with the pump? Position the rad over the block and gravity do the rest of the job. Without any noise.
    If that thing is able to work totally passive it couldn't be worse this way.
  2. David
    7 Apr 2009
    I've got to see this. Subbed.
    I was just thinking about cracking open my router, and sticking some kind of HSF in there; but watercooling it? wow. :D
  3. dark_avenger
    dark_avenger Minimodder
    9 Jul 2008
    By using convection? Didn't really think about that but for the low heat load I don't see why not...
    I was just going to get some small heatsinks and use thermal tape to attach them but I've got some small WC blocks that I've been holding onto for just such a project and got the 80mm rad spare so figure why not :clap::dremel:
  4. dark_avenger
    9 Jul 2008
    Finally found the water blocks I had stashed away, should be perfect for this :)
    2.5cm x 2.5cm, tiny little suckers.
    Got some 3M thermal tape should be able to just stick them on :)
  5. Mojo
    Mojo Multimodder
    18 Nov 2011
    with all the space in the casing.. you could prob add a mini itx board to act as a powerful firewall as well. Where did the little blocks come from?? :D
  6. dark_avenger
    9 Jul 2008
    I've got a chip amp that's going in there as well to stream music from the router.
    They were marked as Koolance blocks but can't find the model anywhere.
  7. Mojo
    Mojo Multimodder
    18 Nov 2011
    Good thinking batman!!
    Look forward to seeing it finished!!
  8. mstrchf
    mstrchf What's a Dremel?
    19 Apr 2008
    Gloriously OTT! Can't wait to see how this turns out.
  9. Mojo
    Mojo Multimodder
    18 Nov 2011
    Been 4 days.. any luck :D
  10. dark_avenger
    9 Jul 2008
    Been trying to find some Y shaped joiners so that both heatsinks will come in one way and back in the other side.
    Without them I don't think the Thermalsiphon effect will work.
  11. Mojo
    Mojo Multimodder
    18 Nov 2011
  12. dark_avenger
    9 Jul 2008
  13. Mojo
    Mojo Multimodder
    18 Nov 2011
    if you goto a car place... standard car fuel line is 6mm :)
    they might have something slightly smaller
  14. OmightyOne
    OmightyOne Minimodder
    7 Nov 2011
    modding to the extreme!, would love to do this to my router(allways overheating)
  15. dark_avenger
    9 Jul 2008
    Sorry for the delay everyone, my partner and I just had a baby so things have been a bit hectic to say the least!
    Now some progress!
    Front panel of the case, still need a fair bit of work with the file but getting there.
    80mm fan hole for the rad, toggle switches for modem, router and amp. RCA plugs for amp output.
    Everything just about mounted, got to source a power supply for the modem/router and mount the transformer for the amp but getting there :rock:
  16. legoman
    legoman breaker of things
    28 Feb 2010
    Isnt that heatsink on the VRM's a tad overkill?
  17. dark_avenger
    9 Jul 2008
    Their the chips for the amp, more than overkill but it fitted well and was in my junk box :D
  18. GaryP
    GaryP RIP Tel
    31 Aug 2009
    Of course it is. The whole project is overkill !! LOL
  19. jamesn
    jamesn What's a Dremel?
    15 Jan 2012
    this is brilliantly superfluous!
