Guides Water-Cooling with Hardline Tubing Guide: Brass and Carbon Fibre
Discussion in 'Article Discussion' started by bit-tech, 1 Feb 2018.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. Vault-Tec
    30 Aug 2015
    Very cool ! I finally know how hard line fittings work. I have a res that uses the same principle. So I guess this is similar, only in mini lol.
    I guess for people like me with no work space (apart from the kitchen) the belt sander is out, but a Dremel would do.
    Thanks for this Alex. I might feel brave enough to give it a crack somewhen in the future.
  3. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    Tbh just use hand tools, the Dremel will just be more of a pain, especially with carbon, brass is very easy with hand tools actually. The belt sander thing was mostly because I have one so may as well show it haha, a number of folks have gotten small ones recently thanks to the surge in amateur knifemaking. These pre-fab parts are really easy to work with, definitely give them a look, Barrow has some great value parts on Aliexpress.
  4. Guest-56605
    Guest-56605 Guest
    Carbon I will say definitely appeals :thumb: :grin:
  5. Vault-Tec
    30 Aug 2015
    I used to have a belt sander. The stick ones you hold. Used to use it to carve shapes in speaker boxes and round of the edges.
  6. Cheapskate
    13 May 2007
    Great stuff. Needs a mention of plumber's silicone grease.
  7. Maki role
    9 Jan 2012
    For the O-rings?
  8. Cheapskate
    13 May 2007
    Yes. It's used to install sink parts with O-rings and lube O-ring valves. It saves you from wearing out the rings during test fitting too.
  9. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    Chromed tubing is very tempting. I've heard a lot of conflicting info on what tube to get if you want to add the bends yourself (using a pipe bender), an equal number of "only used annealed tube or the coating will all fall off!" and "don't use annealed tubing or the tube will snap!".
  10. Maki role
    9 Jan 2012
    I will say that this tubing in particular is very pretty indeed, but you won't want the extruded varieties as they look a bit pants.
  11. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    edzieba likes this.
  12. Gra-ham
    Gra-ham What's a Dremel?
    23 Jan 2018
    I have used 16mm o/d 316 Stainless steel in my build.
Tags: Add Tags
