Scratch Build – In Progress Waterblock for CPU
Discussion in 'Project Logs' started by MKsoft, 31 Aug 2013.
  1. MKsoft
    MKsoft What's a Dremel?
    7 Mar 2011
    Recently changed components, and decided to switch to water-cooling.
    Buy a store does not want to, so he did.
    Taken as a basis Alphacool NexXxoS X2 Hiflow Bold
    And away we go....
    Modeled parts
    And began production.
    As a result, the following happened.
    Copper. The lower part.
    Brass middle part. Top side.
    Brass middle part. Bottom side.
    Details after sanding, sandblasting and coating.
    Now bear for gaskets.
    Mold will be out of the sealant.
    Let's start with the forms. Milling of Plexiglas.
    Then apply a separating layer, so that the sealant is not stuck to the walls of the mold.
    Putting together the two halves.
    And begin to drive the sealant.
    As a result, fill completely.
    A day untwist, sever and voila.
    Fitting.
    And now the most "delicious", the upper part.
    In the model looks like.
    Sticking a piece, transparent + black plexiglass. Milling recesses therein.
    Then fill the resulting deepening cold enamel. After drying, grind, polish and cut the threads 1/4.
    And finally, all three parts side by side.
    Next in line radiator ....
    Pranja likes this.
  2. Derick
    Derick Senpai Studios
    26 May 2012
    Cool!
  3. Furball Zen
    Furball Zen Shut up and Mod
    25 Jan 2012
    Geezle.... :)
  4. Pierre3400
    Pierre3400 What's a Dremel?
    22 Aug 2013
    I am curious to see how will work once it is done. Why not go all out copper?
    But does look great so far!
  5. Hukkel
    Hukkel James' minion
    20 Dec 2012
    Looks very good!
  6. Z0DIAX
    Z0DIAX bending alloys
    26 Jul 2013
    looks very good, almost tron like.
  7. MKsoft
    7 Mar 2011
    :D He is!
  8. skyrip
    skyrip What's a Dremel?
    22 Jun 2013
    why didnt you take the base of a decent performance block? since you could have used a heatkiller lc bottom for only 25 euro.
    must say your way of making an oring is quite smart.
  9. MKsoft
    7 Mar 2011
    Because the middle part, in principle, does not take part in the process of heat transfer, it pumps the flow to the center of the heat sink.
  10. tr0yst3r
    tr0yst3r What's a Dremel?
    27 Aug 2013
    That plexiglass top design looks amazing. Milling it and then using cold enamel, I would of never thought of that. lol.
  11. Cheapskate
    13 May 2007
    Cold enamel-BRILLIANT! :D That fixes the limited color problem.:thumb:
    I've tried making my own seals like that too, but they always ripped or stuck to the mold. Any tips?
  12. MKsoft
    7 Mar 2011
    Spacer layer - the usual soap. A saturated solution is applied to the form and dried. Crushing through a syringe.
  13. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    This is brilliant, especially the oring-mold
  14. asura
    asura jack of all trades
    22 Apr 2009
    Very nicely done! Are injection plates the thing in waterblocks again? They fell out of fashion for a long while and I never quite understood why...
    Did you/have you looked at the work of Cathar? The G4 became the Swiftech Storm, the G5 was a limited run of silver blocks, and he (unfortunately) never made the G6's or G7's. Rather than injecting at a pin array, the injectors focused the coolant into pits (or cups) each with a pin inside here's probably the best set of images still around.
    He skipped the G6 and planned but never created G7. Each iteration used the same area of the cold-plate for the cups&pins but had increased numbers of pits diagonally (centre to edge) 5 in the G5, the 4 in the G4 and it would have been 7 in the G7.
    Interesting design, but fairly expensive to implement well.
    oop - there we go, prototype C7
  15. Furball Zen
    25 Jan 2012
    Um EK and XSPC have them? Unless they are called something else.
  16. Marquee
    Marquee Mac Pro Modder
    22 Jul 2005
    that looks sweet. I also really like how you made the o-ring.
  17. Concept73
    Concept73 Wannabe modder.
    30 Aug 2013
    looks so cool!
  18. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    Love it
