Planning Watercooled HTPC rig
Discussion in 'Modding' started by Thatguy119, 23 May 2012.
  1. Thatguy119
    Thatguy119 Minimodder
    17 Nov 2008
    Hi all, my build is now a few years old and I am looking to upgrade to Ivy bridge, but at the same time fit it in a HTPC due to space issues among other things, including the location of my big screen.
    Due to desire to overclock and 3770k and the surrounding tech giving off heat I am looking to watercool, and wondered if anyone has had experience watercooling a HTPC case using a custom loop (I don't want to use one of the corsair pre made things due to noise) I will be using a micro atx board most likely and looking to fit a dual rad.
    Thanks
  2. Guest-16
    Guest-16 Guest
    I want to see the outcome whatever it is! :D
    1) Pick your budget
    2) Pick your HTPC case to fit the hardware
    3) Pick watercooling kit to fit the case
    Wait - why do you want a 3770K in a HTPC? It's a gaming machine too?
  3. Thatguy119
    17 Nov 2008
    Yeah it's a gaming machine as well, my sole PC apart from a download server.
    Case budget including any required mods - £250, hopefully that will not be a limiting factor.
    The hardware I will be using:
    Asus maximus v gene
    Corsair AX 850w
    1 SSD, no mechanical drive
    GTX 670
    The case is the question, I have no idea which one to go with. I am thinking that the only option may be a roof mounted rad, not sure how that will work though. I was considering a Lian li pc-C60b, but I do not want to spend £160 just to see it and maybe find out I will not work.
    Watercooling wise, a double rad, a triple would be ideal but I think unrealistic. I want to watercool the CPU and probably the graphics card, not sure whether that is too much heat for a double rad though.
  4. Guest-16
    Guest-16 Guest
    I cooled a GTX 480 and 2500K on a triple 120, so a 670 on a double is do-able I recon.
  5. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    And I'm doing exactly that on a triple right now in the Sig rig. Although to be fair I will be upping it to a quad in a few weeks.
    Sent from my HTC Wildfire S A510e using Tapatalk 2
  6. Thatguy119
    17 Nov 2008
    Well after spending many hours looking at various HTPC cases I can see why this has not been attempted before to any success that I can find. There seems simply to be not enough room in a HTPC case for a double rad without roof mounting it, which is obviously not practical. Even using the Lian li pc-C60b which seemed like one of the most promising options does not work because, even if I cut out the 5.1/4 inch bay and have no optical drive, the motherboard still gets in the way. Alas, I think a custom case would be the only way for this to work most likely, unless anyone has a way of making a lid mounted rad work of course :p
  7. dunx
    dunx ITX is where it's at !
    1 Sep 2010
    Re-position the PSU under the CPU vent, and using a Gene you have three PCI-E slots free, lose the HDD cages and there's acres of room, IMHO.
    :D
    dunx
  8. Thatguy119
    17 Nov 2008
    Not quite sure what you mean mate, but I am intrigued. What CPU vent did you mean? And are you implying there will be room for a rad and PSU using the empty expansion slots?
  9. dunx
    1 Sep 2010
    PSU above I/O panel sucking in through the top "blow hole" and exhausting out the back...
    And yes, empty PCI-E slots + PSU relocated = lots of space !
    Brave to chop up an expensive case though !
    dunx
  10. Thatguy119
    17 Nov 2008
    Would a CPU above the I/O panel at the back not be way to long and interfere with the CPU block. And it would not be me cutting, don't worry - this kind of work is the reason Chilled PC exists.
