Watercooling Watercooling build
Discussion in 'Hardware' started by kirk46, 18 Aug 2012.
  1. kirk46
    kirk46 Cheesecake Nom Nom
    9 Jun 2012
  2. aNuclearPidgeon
    aNuclearPidgeon Minimodder
    3 Mar 2011
    You're cooling 2 CPUs but you're only putting 1 CPU block on your cart?
  3. kirk46
    9 Jun 2012
    yeah i know theres only one, as seen as aquatuning dont have any in stock
    ive just realised the pump has barbed fittings so i will have to buy 2 clamps?
  4. debs3759
    debs3759 Was that a warranty I just broke?
    10 Oct 2011
    Did you realise the pump comes with 1/2 inch barbs, and you are using 5/16 tubing? You might be better to get the model with a D5 top, which has high flow and G1/4 threads.
  5. kirk46
    9 Jun 2012
    which one do i need debs?
  6. law99
    law99 Custom User Title
    24 Sep 2009
    I think you can just buy a top like this. There is a manual for installing it.
  7. debs3759
    10 Oct 2011
  8. law99
    24 Sep 2009
    That does look the easier option. I'd do that... especially if it is cheaper!
  9. kirk46
    9 Jun 2012
    Thanks guys
    I'll look at the links in the morning, I've just gone to bed lol :D
  10. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Apparently Mayhems Aurora is just for show and gunks up and stuff, so maybe something else would be better? Or give it a go and let us know :)
  11. kirk46
    9 Jun 2012
    yeah ive read that its for show only. but it doesnt state that on there website?
    ive seen a couple of reviews and its been in there system for a couple on months with no issues?
  12. kirk46
    9 Jun 2012
  13. kirk46
    9 Jun 2012
    what about THIS Setup?
  14. faugusztin
    11 Aug 2008
    http://www.mayhems.co.uk/front/aurora-1.html
    -> http://mayhems-aurora.wikispaces.com/
  15. kirk46
    9 Jun 2012
  16. kirk46
    9 Jun 2012
  17. Bloody_Pete
    11 Aug 2008
  18. kirk46
    9 Jun 2012
    distilled water :)
    nice and cheap
