Watercooling help
Discussion in 'Hardware' started by floppyeardbunny, 24 Oct 2007.
  1. floppyeardbunny
    floppyeardbunny What's a Dremel?
    4 Jan 2006
    I've been looking for some time for a small radiator. I am looking for something to fit in a 19" racak mount server and I've found some to fit a 2U and 3U but as I said I am looking for a small one. I need one that will fit in 1U thats about 40mm. If anyone knows of something or someplace to find one I'd be very appriciative.
  2. Scirocco
    Scirocco Boobs, I have them, you lose.
    3 Jul 2007
  3. floppyeardbunny
    4 Jan 2006
    YOU RULE!!!!!
    I will bow at your feet and call you MASTER errrr MISSTRESS!!!!
    Or in other words THANKS
    :clap:
  4. Scirocco
    3 Jul 2007
    Glad to be of assistance, sir! If you do get that, perhaps you should let us know the results you have with it. I'm sure there's a number of people with small form factor PCs that have thought about water cooling if they could.
  5. floppyeardbunny
    4 Jan 2006
    Good idea, I have to document all my mad experiments anyway so should be easy enough to pass on the knowledge.
