Cooling WC Loop - Look About Right?
Discussion in 'Hardware' started by JavaDog, 17 Sep 2004.
  1. JavaDog
    JavaDog What's a Dremel?
    13 Mar 2004
    This is what I was thinking, but I might be off...so, hows it look?
  2. slater
    slater Mummy Says Im Special
    18 Apr 2003
    U gotta put the res directly infront of the pump :thumb:
    Edit; also the pump inlet/outlet is the other way round. Outlet is on the top :)
  3. JavaDog
    13 Mar 2004
    Why should I put the res infront of the pump? :eyebrow:
    Yeah, was easier to draw that way... :thumb:
  4. Hamish
    Hamish What's a Dremel?
    25 Nov 2002
    yea thats fine, is how i ran mine :)
    can also swap the pump/rad
    either of those configurations will work well
  5. coolmiester
    coolmiester Coolermaster Legend
    31 Dec 2002
    Putting the res in front of the pump makes sure the pump is never starved of water :thumb:
    /.........and the rad before the CPU means you got coldest water going direct onto CPU :thumb:
    Doesn't make a great deal of difference but you may as well get it right first time :thumb:
  6. JavaDog
    13 Mar 2004
    Well, in a topped-off closed system, I don't really understand how a pump could get starved. :confused:
    From what I have read, the heat a pump dumps into the system only equates to a .19*F increase in overall temp, on average...
  7. slater
    18 Apr 2003
    Well centrafugal pumps are relly relly bad at sucking so they need a direct supply of water to the inlet. (ie you need to put the res as close to the inlet as possible)
    If you put a rad or waterblock (or even small tubing) between your res and pump this will restrict the inlet and your temps will be bad. Sure it will work the way you have it but your wasting alot of performance.
  8. Darv
    Darv Bling!!
    12 Aug 2002
    tbh I have mine set up like that and it's fine. There's plenty of water in the system so the pump will never be starved of water.
    For what you may gain in performance you will lose with tubing all over the place, going back and forth.
    When I next refill my system I may try it with pump, rad, block, res and see if it makes a substantial difference.
  9. dreamreality
    dreamreality What's a Dremel?
    4 Mar 2003
    i would have it so the pump is pushing water into the rad and from the rad directly to the cpu. you usually want the coldest water possible to the waterblock. it doesnt help significantly, but it still helps if your pump pumps out a lot of wattage.l
  10. jaguarking11
    jaguarking11 Peterbilt-strong
    10 Dec 2003
    Im runing my setup kind of diferently.
    goes as follows
    pump>>rad>>cpu>>gpu>>res>>pump
    I am using only one pump (hydor L30)
    maybe you want to run it this way?
