Steam webclient helper
Discussion in 'Gaming' started by Ryu_ookami, 11 Dec 2024.
  1. Ryu_ookami
    Ryu_ookami I write therefore I suffer.
    11 Mar 2004
    I've got a problem with steam I'm getting a page that says the steam webhelper client is unable to start. steam doesn't even start for me, it goes straight to the restart with gpu acceleration disabled etc page, then restarts steam and goes right back to the same page.
    I've tried uninstalling and then restarting and then reinstalling and same thing happens was working fine this morning and now nothing. There's been no hardware changes no drivers updated or anything like that in between it working and it not working.
    I'm on windows 10.
    If anyone else has had the issue and knows a fix or work around that they could post that would be awesome Steam Error.jpg
  2. MightyBenihana
    MightyBenihana Colour my life with the chaos of trouble
    8 Sep 2011
    When you say you uninstalled steam, did you delete the user data too, or just the client?
    Are you using second monitor?
    Ryu_ookami likes this.
  3. Ryu_ookami
    11 Mar 2004
    The client. I'm not sure where the user data would be.
    You are a god send I thought all the user data was in the steam folder so i went looking for a hidden user data in the hidden local folder found it deleted and it worked.
    THANK YOU
  4. MightyBenihana
    8 Sep 2011
    Glad it worked.
