Motors What am I getting myself into?
Discussion in 'General' started by chimmy09, 28 Jun 2010.
  1. chimmy09
    chimmy09 What's a Dremel?
    26 Jan 2010
    Well... I am going to try to fix this car. It is a 1985 Ford Mustang LX convertible. The car used to be my uncles, and I don't feel like typing out the whole story right now, so I will either edit this later, or anyone can just PM me if they want more details.
    To be honest, I don't really no enough about cars to fix any major problems. I can change the oil, change the tires, and do some minor things with the brakes, but that is the current extent of my automotive knowledge. In the Fall I will be taking classes at my local Community College to learn how to become a mechanic. Anyways, since my family(grandparents) has had this car that has been gathering dust literally for years, they have decided to give it to me, assuming I can get it fixed up. I plan to do as much of the labor as possible myself(with help from my stepdad), but will be most likely taking it in for any body work that I have done to it. Anyways, here it is.
    that's me
    this is my stepdad
    Well I think that is enough of the outside(since its pretty much everything)
    Anyways, now to move on to the engine.
    So yea, I have more pics, but I figure this is enough for now.
  2. bigsharn
    bigsharn Officially demotivated
    9 May 2008
    Well... Good luck
    The only tip I have is to get yourself a good pressure washer :p
  3. Brooxy
    Brooxy Loser of the Game
    20 Apr 2006
    I'll be watching this. Are you going to be doing the engine GOO style? Strip it clean it and put it back together, or just replace the required parts?
    That car would look awesome in bright red / black
  4. docodine
    docodine killed a guy once
    10 Feb 2007
    Nice, fox body Mustangs are fun cars.
    Get ready to dump a lot of money into fixing this thing. :eek:
  5. Guest-23315
    Guest-23315 Guest
    Sub'd.
    This should be goooood
  6. Pieface
    Pieface Modder
    8 Mar 2009
    I'd hate to see the paint underneath all that bird muck. Probably destroyed with the acid.
  7. Jipa
    5 Feb 2004
    I know barely anything about repairing cars, but project logs like this always get me interested.
    Though for starters I'd like to see it thoroughly cleaned just to see how wrecked it actually is..
  8. earlydoors
    earlydoors Minimodder
    12 May 2009
    Where do you start?!
    Mate, that's going to take ages...good luck
  9. capnPedro
    11 Apr 2007
    Hose it down.
    Reinsert radiator.
    Drain the sump. Change the oil.
    Clean the carb.
    Replace the missing belts.
    Check/gap/replace spark-plugs.
    Insert fuel and battery.
    Pray.
    Does it start?
    No? blood sacrifice.
    Does it start now?
    Seriously, good luck!
  10. docodine
    10 Feb 2007
    Was it stored in a chicken coop?
  11. Cptn-Inafinus
    Cptn-Inafinus Minimodder
    3 Mar 2007
    How can you get any idea of what you are going to do underneath all that crap! I'm sure this will be pretty cool!
  12. C-Sniper
    C-Sniper Stop Trolling this space Ądmins!
    17 Jun 2007
    Actually for finding out problems this isn't a bad way to start. I would highly recommend starting with the mechanical/ engine electrical issues before worrying about the body. Doing it this way you can at least then drive it to a body shop or to where ever you need to go for parts.
    This should be a fun one to watch
    *grabs popcorn and reclines chair*
  13. kenco_uk
    28 Nov 2003
    Bit of t-cut'll sort that out.
    :p
  14. chimmy09
    26 Jan 2010
    I want to start by cleaning it off, but I need to move it before I can do that. It is being stored in my aunt's barn/shed. All the crap covering it is from magpies and starlings. From what I can tell, the only real problems with the body is the front driver side fender, and the driver side door. The top seems to be in fair condition though, which is good. I may eventually repaint it a different color, but for right now, it is going to stay blue because of the interior, and I don't want to spend the money now to get it reupholstered.
    Anyways, for the engine, I plan on first replacing the parts that are missing, and then taking apart/cleaning/rebuilding the parts it has in it. It needs all new hoses and belts, because it looks like the hoses that were in there were just cut out with a saw. Oh, and that driver side door doesn't open from the outside.
  15. Matticus
    Matticus ...
    23 Feb 2008
    This. Looks like the worst affected area will need replacing anyway, which is handy.
  16. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    Me watches..
  17. Grimloon
    Grimloon What's a Dremel?
    4 Sep 2008
    ...and the sacrifice in question (at least when I'm doing it) is usually my own. Squashed finger/thumb, heavy object dropped on toes and/or gashed limb as an offering to the machine spirits. Nothing seems to go right until I've received at least one injury and sworn a blue streak for over 5 mins or over 120 dB, whichever comes first! :D
    Best of luck with this one, it hopefully looks much worse than it is but I'll be watching this thread either way.
  18. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    What've you got yourself into?
    A boat car-load of work, it looks like :p
    Looking forward to seeing a worklog!
  19. trekkypj
    trekkypj Forward Momentum!!!
    23 Jun 2010
    Soooo will the car be featuring on the Custom PC mod of the month page? ;) Better yet, build a pc styled to match :).
    Oh and if you haven't got a copy yet,
    http://www.haynes.com/products/productID/158
    Good luck! It'll eat money for a while but when you have it sorted it'll be a beaut!.
  20. capnPedro
    11 Apr 2007
    That totally what I was thinking about.
    Reassembly is the reverse of disassembly (but this time don't let the screwdriver slip and stab your hand).
    Also, if this is the first repair job you've done, look forward to having to make your own tools. Prepare for grinding notches into sockets, bolting little steel I-beams together to jam into the fly wheel, extending your breaker bar with steel box section... good times. Good times.
    And buy plenty of oil, because you'll probably be using it to find leaks. :lol:
