Displays What are the current best duel screen budget monitors
Discussion in 'Hardware' started by jamsand, 24 May 2014.
  1. jamsand
    jamsand Minimodder
    21 May 2011
    Hey I'm looking at getting a duel screen set-up as it makes coding so much easier and thought I might as well invest in a decent pair of monitors that will look nice and go well together rather than just buying a 19inch £50 number with that said I don't want to go over the 300-400 marks preferably on the lower end of the scale. Preferred screen size is around the 22 mark. Recommendations please?
  2. mansueto
    mansueto Too broke to mod
    31 Aug 2007
    If you're strictly coding have you considered using one of those cheap 19" monitors in portrait format instead of landscape? Get a nice 22-24" main monitor, and a budget secondary for landscape / coding / reading.
  3. aLtikal
    aLtikal 1338-One step infront of the pro's
    7 May 2008
    I'm a front end developer and I currently work on a Dell U2414H. Will deffo be getting another when money allows. Might be slightly over your budget but I reckon there the best monitor for the price point they come in at.
  4. SimonStern
    SimonStern Registered Lurker
    28 Dec 2010
    Obviously I couldn't resist. I'll get my coat :worried:
    ferret141 likes this.
  5. microsoftPerson
    microsoftPerson What's a Dremel?
    27 Dec 2010
    LMAO
