Cases What case should I get for a 5850?
Discussion in 'Hardware' started by butter100fly, 30 Sep 2009.
  1. butter100fly
    butter100fly Rebelstar Raider
    16 Sep 2009
    Anandtech's review is up
    The 5850 has power sockets in the back, which would give it a similar length requirement in case terms to the 5870
    I want a sub £100 air-cooling or h50 case for medium overclocking with good airflow yet as quiet as possible when fans are on low (so I guess that means a 200mil roof fan amongst other things)
    In which cases will it fit, and what would you good folks recommend? I'm still rooting for Antec902 or HAF922 at the minute....
  2. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
  3. butter100fly
    16 Sep 2009
    thanks
    Xclio
    So that seems good...maybe take this thread on a different tack - what popular cases won't work?
  4. Diosjenin
    Diosjenin Thinker, Tweaker, Et Cetera
    14 Jul 2008
    Uhh... Mini-ITX cases. That's basically it.
    The 5850 comes in at 9.5" long, and a standard ATX/mATX board is 9.6" deep. The only catch would be that the PCI-E power plugs face out the end of the card rather than up from the top, so make sure that there isn't anything (especially a hard drive cage) that comes right up against the edge of the motherboard, and you're golden.
    Google/Bing some reviews and/or images of the case you want, and you'll probably find a number of pictures of boards installed in the case. That should give you an idea of length issues pretty quickly (and reviews will likely tell you straight up if there's any issues).
    - Diosjenin -
  5. ashikamlani
    ashikamlani What's a Dremel?
    11 Mar 2006
    +1 on HAF 922. Great case, and would fit a 5850 with absolutely no problemo
  6. Elton
    23 Jan 2009
    If you can fit a HD4870 or a HD4850 in your case, this will fit.
  7. butter100fly
    16 Sep 2009
    Ah ok - so the length problems that have been raised here and elsewhere are more about what else is in your case and how its been organised, right.....
    stock 5850 is a fair bit quieter than 5870. Still wondering which of the cheap-ish cases might dampen sound best or necessitate least fan-whine. The missus needs keeping happy as well as Crysis...both are demanding....
  8. Carper
    Carper Guru
    19 Aug 2009
    the antec 902 case should be fine for the 5850 then right?
  9. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    902 = bad
    922 = good
  10. Diosjenin
    14 Jul 2008
    Sorry - what's bad about the 902? I was under the impression that most people's problem with it was that it wasn't enough of a step up from the already überpopular 900.
  11. Carper
    Carper Guru
    19 Aug 2009
    alot of reviews for the 900/902 are very high. its a good case for the price. also ALOT of people have the 900 due to its cooling. with the 900/902 being pretty much the same im sure it isnt bad. although its your opinion maybe next time more information on it. :thumb:
