Modding What color sleeving?
Discussion in 'Modding' started by Bboy_Jon, 30 Sep 2004.
  1. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    Missouri
    THis is the inside of my case
    should i get UV blue sleeve or UV green sleeve? And what kit/where should i get it?
  2. ¿þŘΩĐĮĢΫ?
    ¿þŘΩĐĮĢΫ? What's a Dremel?
    13 Jun 2004
    Alberta, Canada
    first off i would suugeust toning the size of those pics down a bit 1024-768 pixels, then i would suggeust blue or black sleeving, cause black goes good with any color, but the blue would be a nice touch, and in personal opinion, don't go U/V i don't like the color of it but thats me
  3. diskreet
    diskreet What's a Dremel?
    1 Oct 2003
    Pennsylvania USA
    color wise i would go with UV blue, or blue. that will match your LED fans.
    any sleeving from Performance PC's will do you well. theirs are all top notch quality parts. take a look!
    As soon as they get back up and running I would buy from them. Unfortunatly They did get hit by the newest hurricane so it might be a few days yet. If nothing else Frozen CPU will have just as good sleeving at a comparable price.
  4. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    Missouri
    i kinda want blue or green
    also what round ide cables should i get? blue or green?
    should i get a new round floppy cable? (i have a antec cobra and i know its good but its ugly imo, can i put the sleeving around that?)
  5. hilmana
    hilmana What's a Dremel?
    20 Aug 2004
    malta
    i say that deppends
    do u want the wires to be "camoflaged" (barely vizzable) them go for blue or do u want them tho stick out and show then go for green
  6. alter_ego
    alter_ego What's a Dremel?
    26 Jun 2004
    UK
    sorry to hijack ure thread, but does anyone know any uk retailers of chrome cable sleeving
  7. epidemik
    epidemik What's a Dremel?
    11 Sep 2004
    australia
    i sleeved my cables black and it looks so **** .
    so i am ordering the green kit . :rock:
  8. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    Missouri
    ya i think black would look funky
  9. retrogamer
    retrogamer What's a Dremel?
    23 Aug 2004
    England
    defo go for some UV blue that would look sweesh :D
  10. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    Missouri
    FOr the red led, can i color it with black (or blue if i have any) permanent marker? or would that screw it up? and could i cover it with electric tape?
    Can the electric tape touch other parts too?
    like this
    can the tape touch a bunch of parts and it wont do anything?
  11. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    Suffolk
    those pics are massive mate, resize em.
  12. retrogamer
    23 Aug 2004
    England
    the tape shouldnt make any difference :thumb: tape away :p
  13. nizon
    nizon What's a Dremel?
    15 Mar 2004
    Winnipeg, MB
    Electrical tape won't completely block the light
    If you have the balls, your best option might be to desolder the LED
    If not, try painting it then covering it with tape.
  14. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    Missouri
    if i get a blue cold cathode would the blue light be strong enough to stop most of the red light?
    basically i can tape up my whole mobo or something?
  15. Mace
    Mace Ohh, it stings.
    9 Dec 2003
    Michigan, USA
    Eh, a little electrical tape wont hurt the LED, I'd take some black, wrap it around itself for about a 1"-1" square, then tape it over the red LED on your mobo...
    Otherwise, find something completely opaque (Perhaps a small piece of rubber-coated metal) and place that over the led.. I have some blue cathodes and they drown out the red led so it's not really anything to worry about!
  16. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    Missouri
    i could just get some electric tape then put duct tape over the tape then put more electric tape
  17. Mace
    9 Dec 2003
    Michigan, USA
    Hehe, don't be afraid to use electrical tape... that is why they call it electrical tape :p
    Maybe consider taking a piece of hard black plastic and cutting it to about .5x.5"
  18. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    Missouri
