Cooling What cpu temp software do you use?
Discussion in 'Hardware' started by chrisb2e9, 14 Oct 2008.
  1. chrisb2e9
    chrisb2e9 Dont do that...
    18 Jun 2007
    Just wondering what program everyone uses? I'm overclocking my system again and I've noticed that different programs give different results.
    Tried Core temp and Real temp so far.
    Core temp reported my q6600 hit 77 degrees. While real temp was only 63. I'm tempted to believe real temp because i'm only at 2.7ghz right now. and I've had this thing up to 3.2 stable before.
    So what program do you trust?
  2. lxrysprtmscl
    lxrysprtmscl Minimodder
    8 Sep 2008
    i use cpu-id's HWMonitor along with CoreTemp.
    i like how HWMonitor gives hdd, cpu, gpu, etc temperatures along with voltages.
    lxrysprtmscl.
  3. bubsterboo
    bubsterboo What's a Dremel?
    24 Jan 2006
    Everest, with the Vista sidebar gadget. Works fine as far as I can tell.
  4. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    lmsensors
  5. wyx087
    wyx087 Multimodder
    15 Aug 2007
    Everest and CoreTemp gave me the same temperature, RealTemp gives me a little difference because its TJMax is set to 95 instead of q6600's 100c. manually change RealTemp made sure all my software giving me the same temperature.
    im thinking about Speedfan and use this CPU Usage gadget i just found. apparently can read off Speedfan's readings.
  6. LeMaltor
    LeMaltor >^_^
    3 Oct 2003
    Coretemp and rivatuner
  7. Shielder
    Shielder Live long & prosper!
    26 Jul 2007
    +1 for lmsensors :)
  8. Akava
    Akava Lurking...
    28 Jul 2007
    Yes it can, I used it for a little while then decided that i don't like Sidebar that much so i just use Speedfan now.
  9. crazybob
    crazybob Voice of Reason
    21 Oct 2004
    For quick measurements of other people's computers, I tend to use CoreTemp. For my own system, though, I like to have SpeedFan running at all times. It's a huge pain to set up well, as it doesn't even try to guess sensor names and the labels are pretty random, but once you struggle through that and figure out what each component is, it's fantastic. It provides temperatures for CPU, GPU, hard drives, and chipset all in one place, and offers fan control as well.
