CPU What cpu to pair with a320?
Discussion in 'Hardware' started by Greentrident, 23 Aug 2021.
APU or CPU
Poll closed 30 Aug 2021.
  1. APU
    50.0%
  2. CPU
    50.0%
  3. Neither
    0 vote(s)
    0.0%
  1. Greentrident
    Greentrident Minimodder
    10 Jul 2009
    I have a gigabyte a320m-h which I bought for no reason other than it was £19.99! I'm initially thinking put it in my ML04b which is low profile so would benefit from an APU. Looking at prices for APUs (even used) I get the feeling I should consider just using it to replace my athon fx 8350 system and go for something like a ryzen 3600 or second hand 2600. Feels strange as it would be a very budget upgrade but my old system is pretty long in the tooth and since I can't really get a replacement for my r9 380 I'm not going to be able to majorly upgrade performance just yet.
    So budget htpc with APU or ultra budget replacement for the athlon, and in either case which cpu?
  2. Arboreal
    21 Jan 2011
    Decent APUs look hard to come by at the moment, if you have a spare GPU, definitely consider the R5 2600/3600 CPUs.
    I've been playing with a B450M with an R3 1200, which seems to be about as powerful as a non K Skylake i5 CPU. I'll put a 3600 in it when I find a suitably affordable GPU for it.
  3. tech-man
    tech-man What's a Dremel?
    23 Aug 2021
    I have B450 Pro and Ryzen 3600, and it's enough powerful to play games, just have 1030 ( 2GB) graphic card. You should go for 3600 Ryzen. Buy it now before price will go up 10 %
  4. Sgoaty
    Sgoaty Multimodder
    4 Feb 2005
    You inspired me to buy the same board don't know what I'll use it for either :hehe:
  5. Greentrident
    10 Jul 2009
    The dangers of bargain priced kit!
  6. Sgoaty
    Sgoaty Multimodder
    4 Feb 2005
    I'd say an any first or second gen Ryxen X SKU if third gen I wouldn't be so worried about getting an X
    Greentrident likes this.
  7. Sgoaty
    Sgoaty Multimodder
    4 Feb 2005
    I managed to pick up a 2600X for mine :)
  8. Greentrident
    10 Jul 2009
    Looks like a good option! Ebay?
  9. Sgoaty
    Sgoaty Multimodder
    4 Feb 2005
    OCUK forum £70, I'm still on the look out for a deal on a 3000 series CPU if I find one I'll be happy to pass along the 2600x for what it cost me :)
    Arboreal likes this.
  10. Greentrident
    10 Jul 2009
    Good luck then! At the moment voting is neck and neck so I think it will come down to whether an bargaining APU or CPU comes up first!
  11. Sgoaty
    Sgoaty Multimodder
    4 Feb 2005
    I think I have sourced a 3600 (before even using the 2600x :hehe:) I will list it on the marketplace and give you first refusal if you want? once the 3600 shows up :)
  12. Greentrident
    10 Jul 2009
    That sounds like a good plan! No rush though, make sure the 3600 is good before you do anything!
  13. Sgoaty
    Sgoaty Multimodder
    4 Feb 2005
    CPUs arrived. I'll list it on the MM @£70 plus postage if you're still interested?
    Thanks
    Scott
  14. Greentrident
    10 Jul 2009
    Sounds good! I will need to check finances so if you list it on the MM I will get back ASAP.
  15. Sgoaty
    Sgoaty Multimodder
    4 Feb 2005
    I gave it a quick try on the board to see how it was. VRM temps in the mid 70s when gaming but got up to 120c after 20 minutes of cinebench, which is total worst case scenario. I've listed it giving you first refusal but. It's no problem if you want to give it a miss.
    Thanks
    Scott
