Hardware What Hardware Should I Buy? - July 2009
Discussion in 'Article Discussion' started by Guest-16, 8 Jul 2009.
  1. Guest-16
    Guest-16 Guest
  2. bogie170
    bogie170 What's a Dremel?
    11 Aug 2008
    Good round up. I'd just like to add those people upgrading to a Q9650 it is an excellent chip. I got mine to 4Ghz stable.
    The only problem being that people with older motherboards P965 and P35 might have problems getting their 2x2Gb Ram running above 950Mhz.
    I know my Asus Commando has this issue and that the Ram will need to be flashed. To do with BIOS problem, not being able to set the TRFC setting to above 42. Most 2x2Gb Ram needs 54.
    More info at the OCZ official support forums.
    http://www.ocztechnologyforum.com/forum/showthread.php?t=36964
    http://www.ocztechnologyforum.com/forum/showthread.php?p=405598#post405598
  3. ashikamlani
    ashikamlani What's a Dremel?
    11 Mar 2006
    Good article, but the Enthusiast Overclocker page does not have any CCL links.
  4. mjm25
    mjm25 What's a Dremel?
    19 Jan 2009
    I still love my 4870x2, easily the best card i've ever had, and thats all the way from a geforce 2 mx back in the day..... actually... i loved that card too, it punched way above its weight i found. oh god.
  5. Guest-16
    Guest-16 Guest
    I know, we're still waiting on them :)
  6. pizan
    pizan that's n00b-tastic
    25 Apr 2008
  7. Almightyrastus
    Almightyrastus On the jazz.
    21 Mar 2002
    With the other bits and pieces I have picked up over the past couple of months the exthusiast system is coming in at under a grand for me now, highly tempting
  8. ashikamlani
    11 Mar 2006
    Ah sorry I thought it was a typo!
  9. wyx087
    wyx087 Multimodder
    15 Aug 2007
    what happened to Bittech? your case recommendations used to have so much class. now it's all tacky LED business (except for the most expensive bundle)
    everything else looks spot on though. can't wait to see what mobo you recommend for LGA1156 when it comes out
  10. Da_Rude_Baboon
    Da_Rude_Baboon What the?
    28 Mar 2002
    Any plans for an updated HTPC buyers guide?
  11. Guest-16
    Guest-16 Guest
    Nope sorry. I'm just not testing HTPC stuff as much as I'd planned in order to give a proper recommendation. :(
  12. tohdom
    tohdom What's a Dremel?
    8 Jul 2009
    i thought seagate 7200.12 1tb beats Samsung F1 in real life?
  13. logan'srun
    logan'srun following the footsteps of giants
    22 Apr 2008
    where's the monitors?
  14. Freemanator
    Freemanator What's a Dremel?
    13 Sep 2005
    Just to echo that.
    Will you be adding the display recommendations this month?
  15. fingerbob69
    fingerbob69 Minimodder
    5 Jul 2009
    I need a monitor recommendation in the £100 to £200 ...not least because reviewers (inc B-T) are always moaning at how similar they are ..."not another TN"!
    Some I have/am considering...
    LG W2261V (looks bueatiful but is that enough?)
    BenQ E2200HD (washed out colours apparanently and strange styling)
    Hyundai W220 (has been recommended but only in one place)
    Samsung Syncmaster T220 (but is it a Samsung screen or a cheaper, poorer quality affiliates???)
    Please, Bit tech needs to stop moaning at the sameness of them all and give some clarity to the visuals!
  16. malikdrako
    malikdrako Minimodder
    27 Sep 2006
  17. Guest-16
    Guest-16 Guest
    We haven't reviewed any for so long we took it out since it wouldn't be current. We only recommend things we know.
  18. Guest-16
    Guest-16 Guest
  19. Spafe
    Spafe What's a Dremel?
    19 Apr 2009
  20. badgerz
    badgerz What's a Dremel?
    15 Feb 2005
    Nice roundup, glad to see the AMD X3 in the list.
    On displays, give the Dell 2209wa a look. Was the best bang-for-buck couple of months ago when I picked one up.
Tags: Add Tags
