Other What is a good TV that's similar to my IPS monitor
Discussion in 'Hardware' started by Siwini, 23 Mar 2012.
  1. Siwini
    Siwini What is 4+no.5?
    14 Sep 2010
    Hi everyone,
    I haven’t own a TV probably in over 5 years now. I always used monitors in the past, but now I need one. It’s obvious that I’m way pass due on this LED/PLASMA (and now I hear about these smarttv’s ) battle so I need your help. I want the picture to be perfect and clear- similar to my IPS monitor if possible (or at least the closest I can). I don’t want big/huge pixels either on display. Obliviously quality has to be there too.
    Here’s the two I’m currently looking at. You’re thought please.
    Samsung 6300LED SONY HX729
  2. Deders
    Deders Modder
    14 Nov 2010
    A large screen TV will always have larger pixels, but then it is designed for being viewed from the other end of the room.
    Edit: It's good that you found a Sony at such a discount, usually their TV's are very overpriced considering you can sometimes get the same panel in much cheaper brands. Not sure if they would have all the extra features though.
  3. docodine
    docodine killed a guy once
    10 Feb 2007
    You won't get a TV which is equivalent to your IPS monitor in terms of picture quality for any reasonable price, just getting that out of the way now.
    Pixel density is going to be low on any TV, the ones worth buying are all 1920x1080 res so you can't avoid that 'large' pixel size.
    Plasmas have better color quality than LCD TVs (don't call them LEDs for the love of god), but you get issues like power consumption, fading, burn-in, etc. They're being slowly phased out in favor of the ever-improving LCD. I would've bought a plasma for sure if this was 3-4 years ago, but now it's not such an easy choice. If only Pioneer still sold the Kuros...
    A smart TV is pretty much just a TV some built in HTPC capabilities like streaming video and possibly an internet browser. Could be useful depending on what you need, for me these features are useless.
    I wouldn't just go out and buy a random TV from a store, they go on sale all the time.
    Check out the Slickdeals TV section. You can always find great deals on TVs there.
    AVSforum is great to read to learn about TVs, check it out.
  4. Da_Rude_Baboon
    Da_Rude_Baboon What the?
    28 Mar 2002
    That's like saying two computers share the same motherboard. The panel alone does not determine the quality of the picture.
  5. Deders
    Deders Modder
    14 Nov 2010
    Kind of what I meant by extra features
  6. Fungalist
    Fungalist What's a Dremel?
    24 Apr 2009
    Is burn-in still an issue these days? I've abused a couple of the big panny plasmas and nothing bad has happened.
    From my (very simplistic) point of view if you plan to game on it or watch a lot of sport go plasma. For anything else, and especially if the room is bright, go lcd.
  7. trig
    trig god's little mistake
    10 Aug 2006
    burn-in isn't an issue...you can do it if you try to lol...but you'd have to really try...i snatched a samsung pn51d8000 on the cheap a few months ago, and it is amazing...defo go with a high quality plasma...
  8. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    That samsung model is quite nice and has an SPVA panel. It's so nice my father bought 2 of them. While the smart features may be a little underwhelming compared to a full blown htpc, it is sufficient for light browsing and being able to plug in a usb drive for direct playack of some of the most common file types like m4v and avi is plenty for his uses.
    Picture looks very good, nice colors and deep black. Has several modes including one that is 1:1 pixel mapping if you do want to use it with a PC.
    After I helped him do quite a bit of research it did come out on top for best picture on a tv with smart features. There are some LG and Toshiba that had a slightly better looking picture that use SIPS, but without the extra features and hundreds of dollars more.
    I think the samsung is a good buy, and with my experience with it would recommend it.
  9. trig
    10 Aug 2006
    :thumb:
  10. Siwini
    14 Sep 2010
    Wow thank you! Some good useful knowledge +rep
  11. Siwini
    14 Sep 2010
    No bleeding problems? I read few reviews on Amazon and seems like it's a big turn off.
    Also what you thing about SAMSUNG 8000 model. It's the newest right? Is it SPVA or SIPS? Thanks!
  12. IvanIvanovich
    31 Aug 2008
    I have not observed any bleeding issues on either of them, on blacks it is dark-dark, but I haven't spent loads of time with them either. I also made sure they were properly set up, unlike many people that just take it out of the box and plug it in and say it looks terrible without calibration. I'm pretty sure it's SPVA, though have seen some sources list them as MVA.
  13. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Yeh, most TV's are set to 'demo, ultra bright' settings by default, so thats why they get bad bleed through when you first get them...
