What is happening?
Discussion in 'Tech Support' started by Asulc, 10 Jul 2008.
  1. Asulc
    Asulc Minimodder
    18 Jul 2007
    I would believe that this is a problem caused by my graphics card. Could someone please tell me what is happening and how I can fix it?:eyebrow:
  2. Fishlock
    Fishlock .o0o.
    22 Nov 2004
    What is your system spec?
    Have you tried wiping and reinstalling your graphics drivers (the latest ones for your graphics card)?
    Sam.
  3. EnglishLion
    EnglishLion working for the good of mankind...
    2 May 2008
    Is this graphical glitch limited to the one application or is it seen across the all programs and on the operating system main screen too?
  4. Guest-23315
    Guest-23315 Guest
    If it were a graphics card issue, the problem wouldn't show on a screenshot :thumb:
    Try re-installing sketchup and your graphics drivers and try again.
  5. Fophillips
    Fophillips What's a Dremel?
    9 Oct 2006
    That isn’t true
  6. Guest-23315
    Guest-23315 Guest
    I see you have evidence, but I thought a sreenie was what the processor thought should be up on the screen, not the entire actual image?
  7. Matticus
    Matticus ...
    23 Feb 2008
    I think its basically what the monitor gets given to play with.
    It definitely looks like a driver issue to me, either that or sketchup is screwed. Try reinstalling both
  8. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Yeah you can screen-cap artifacts ;)
  9. Guest-23315
    Guest-23315 Guest
    My bad then folks, sorry :waah:
