Small Form Factor What is the best memory for Shuttle SN45G v2
Discussion in 'Hardware' started by quadmodz, 16 Jul 2005.
  1. quadmodz
    quadmodz What's a Dremel?
    9 Oct 2004
    Anybody here could help me on what memory i can get? I do choice Corsair but I dont know what is the best model for 512mb DDR400.
    anybody tell me what is the best model that fits on my Shuttle SN45G v2
    thanks
  2. quadmodz
    9 Oct 2004
    anybody here?
    or can i use
  3. JRY
    JRY What's a Dremel?
    28 Feb 2004
    u could check shuttle's ram compatibality list m8 :)
    google for it.
    have used 2x256 Twinmos and am now using 2x512 crucial.
    both seem to be working fine
    hope this helps
  4. pritsey
    pritsey Minimodder
    26 Nov 2002
    I've used some different types in my SN45G before, however I currently use 2 x 512 sticks from Aria - about £22 each - 1 gig for under £50 delivered! Not only that, but it's PC3200 and runs at 200MHz with my XP2500 Barton.
  5. Firehed
    15 Feb 2004
    Any DDR400 should be fine I think. Well, you could use slower, but that's just plain silly.
  6. TMM
    TMM Modder
    12 Jan 2004
    Shuttles are pretty damn picky with ram from what i've heard so i'd look at the shuttle ram compatibility list before ending with ram that your shuttle won't work with :p
  7. Nath
    Nath Your appeal has already been filed.
    28 Dec 2003
    Actually the Shuttle SN45G is notoriously picky about what type of RAM is takes, more specifically which brand.
  8. Diablo668
    Diablo668 What's a Dremel?
    22 Apr 2002
    i'm using mdt brand 2x512 ddr400 cl2.5 in mine, works just fine
