have been using analog x for a while, got an email from blueyonder saying i cannot use it because its insecure!! anyway can anyone reccommend a good proxy thats EASY to setup and can support games preferably
just dont bother setting one up, i dont with mine and everything works perfectly, BY havent sent me an email or anything about it,
why do you need to use a proxy ? are you talking about a webcache here, or some sort of internet connection sharing suite ?
I'm assuming that you used AnalogX's proxy for internet connection sharing. I used it for a bit, but it didn't have great support for AOL (my g/f uses aol a lot, so that was an important feature I needed). I ended up getting a eval copy of Sygate's program to share my cable connection .. and ended up purchasing it. I tried Win98's ICS, but for some reason it would cause my PC to lock up several times a night. I used Sygate for a few months, until I got the Linksys cable router. Vert
Wingate - available at http://www.wingate.com/ Sygate - available at http://www.sygate.com/ Other Links that are mentionable: * http://www.microsoft.com/homenet/ics.htm * http://huizen.dds.nl/~jacco2/isdn/ipr_ispa.html * http://www.nat32.com/ * http://www.uq.edu.au/~gadmacka/the-nat-page/index.html * http://www.pscs.co.uk/software/vsockslight.html * http://www.vicomsoft.com/knowledge/reference/ks.reference.html
