Planning what's the best way to streamline Mobo 4pin?
Discussion in 'Modding' started by nikeunltd, 7 Aug 2009.
  1. nikeunltd
    nikeunltd Epic destruction around machinary
    5 Apr 2008
    Alright,
    Im planning on getting the nice CoolerMaster Storm Scout case with the EVGA E758-A1 Mobo using the CORSAIR CMPSU-750TX
    It is a good combo and all, but the problem i am having is something like this...
    so, what can i do to make sure that doesnt happen??
    I was thinking of running the 4-pin behind the tray, then come in through the square hole in the back, run the cable on top of the mobo, then run the cable down.
    would it work?? if it doesnt, is there another way?? also, how can i find out the length of that power cable?
  2. andrew8200m
    andrew8200m Multimodder
    4 May 2009
    That would work. If theres that much stress on the cable your going to need an extension. These are made by akasa I believe. Dont cost too much but do the job perfectly.
    Andy
    mvagusta likes this.
  3. sentek
    sentek What's a Dremel?
    5 Jul 2009
    corsair dont seem to list the cable lengths on their site,
    but it does say:
    http://www.corsair.com/products/tx/default.aspx
    as the cm storm scout it a mid-tower i would guess there will be plenty of length, and if not you can always get an extension as andrew8200m said..
    as for running the cable behind the mobo tray it would depend on the gap behind the motherboard and maybe which cpu cooler you are using also..
    but even if you cant fit it, you can always run the cable from the psu to the left side of the case near the floor, then to the rear, up the side passed the pci slots, then under/over the fan, and from their to the power connector. just get some cable ties and bases. it doesnt look that nice when the case is opened up, but when the side is on i dont think you would be able to see it and the airflow shouln't be affected..
    sadly there is no space above the motherboard to dremel a little hole out for it :(
    either way it looks like a nice case :)
  4. SNiiPE_DoGG
    SNiiPE_DoGG Engineering The Extreme
    14 Apr 2009
    do this:
    8-pin is soldered to the contacts at the back of the board :thumb: I will be making a guide this week :D
  5. H2O
    H2O Burnt Acrylic - Mmmmmm
    1 Aug 2009
    That is sweet! Will it work for the 24 pin ATX as well?
  6. Horizon
    Horizon Dremel Worthy
    30 May 2008
    Instead of running it in front of the video card run it between the video card and the mobo.
    and under the CPU heatsink if you have to
  7. H2O
    1 Aug 2009
    Just to make sure - does your PSU come with a 8pin ATX connector? If it does, that is what you should be using.
  8. SNiiPE_DoGG
    14 Apr 2009
    yes it would work for 24-pin too, you just have to be very careful about isolating each wire and solder point ;)
  9. lenne0815
    lenne0815 What has been seen cannot be unseen
    4 Jul 2009
    snipe dogg, awesome idea ! im lucky because my cable is just long enough to run behind the tray and u can barely see it at the tot, but ur solution is soo much more... nicer ;)
  10. stuartwood89
    20 Aug 2008
    That pesky 4-pin is always the inevitable cock up when it comes to putting my rig together. It's so easily forgotten about, and once you got your case looking perfect and then realise you missed it, you feel guilty about running that one cable across your motherboard. Life is made a little easier if your PSU is at the top, but routing behind the motherboard tray is your best option.
  11. KillerLettuce
    KillerLettuce custom title
    15 Jan 2009
    yes, just cut a hole in the motherboard tray and run an extension if the cable isnt long enough.
  12. Ending Credits
    Ending Credits Bunned
    4 Jan 2008
    That's a really nice idea but probably not for begginers :p
  13. SNiiPE_DoGG
    14 Apr 2009
    well honestly, I would say soldering the 8-pin to the back of the board is probably the easiest solder job I have ever done (I usually do volt modding) but as with anything in modding, practice makes perfect and everybody's got an old motherboard lying around.
  14. Cheapskate
    13 May 2007
    If you have a soldering iron I'd go for lengthening the wires first.
  15. ry@n
    ry@n Minimodder
    31 Aug 2005
    I bought one those Akasa extensions for my 8 pin and just cut a hole on the mobo tray, still need to re-sleeve it though as Akasa fail badly at that.
  16. nikeunltd
    5 Apr 2008
    THANKS!
    Thank you all!!
    Fortunately, as a computer engineering student and newb modder, soldering stuff is basics for me. i will run the wires by the open hole Horizon suggested first. if that fails, i will run the power cable through the back tray, if its not long enough, i will get a akasa cable (if i can make my own, that would be awesome).
    IF i feel adventurous, i will solder =]:rock:
    thank you all!! i will keep you posted.
  17. dark_avenger
    dark_avenger Minimodder
    9 Jul 2008
    "The Langer" already did that on his PrometheusCU Project
    Linky
  18. nikeunltd
    5 Apr 2008
    change in event. i got an old first verison Antec p180 (with out the two ports on top) lying around and i am going to be using that instead of the coolerMaster. again, would it fit? i hope it will...
  19. nikeunltd
    5 Apr 2008
    im still trying to find akasa PSU 8 pin extender for a low price in the USA. anyone know of any?
  20. Volund
    Volund Am I supposed to care?
    16 Sep 2008
