What's ur temp?
Discussion in 'Hardware' started by MaSHim0t0, 12 Sep 2003.
  1. MaSHim0t0
    MaSHim0t0 What's a Dremel?
    8 Sep 2003
    Hi I was wondering what everyone else was running on their system.
    I'm running XP2000+ with Volcano 9 with Ducting Mod and I get 52 C on regular usage.
  2. Mightybob
    Mightybob What's a Dremel?
    5 Sep 2003
    i have been playing with a stock 1800+ system. Tbred core, Coolermaster HAC-V81. This ting runs at about 20 C idle, and 32 C load. The lowest i have had it at is 10 C at idle.
    Very nice.
  3. Hippo
    Hippo Pre-dates 5.25" Floppies
    7 Mar 2003
    Those temps just dont seem right bob. Wha did you use to measure them ?
    My CPU idles around 40°C going upto 45°C on load
    System temp is around 26-28°C
    All measured with MBM so +-10°C :eeek: :hehe:
  4. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    XP 1800 t/bred B @ 2600, with sunon fan @ 7v, 41°C load, @ 12v, 38°C load.
    currently using ystech silent, 45°C load
    case temps ebtween 27 and 30
  5. Hiren
    Hiren mind control Moderator
    15 May 2002
    MaSHim0t0 - Same setup as you (TT Volcano 9 and XP2000) I'm getting 42-44c on average useage and 48c+ on full load. But I'm looking to replace the volcano 9 soon as it's waay too loud,
  6. fivecheebs
    fivecheebs Dont panic!
    19 Feb 2003
    Barton 2500+ @ 2150mhz (205*10.5) with SLK800 and a smartfanII at about 7vish currently 38-42c idle and 45-48c load. I say currently because the ambient temps change dramatically where my comp is. Last winter with a stock tbird 1.1 and a stock HSF i was getting load temps of 16-20c but ambient temps were often 5-10c.
  7. Hamish
    Hamish What's a Dremel?
    25 Nov 2002
    barton 2500 @ 2.3gig
    low 30's during the day and high 20's at night :)
    watercooled:
    Maze3, bix
  8. Kameleon
    Kameleon is watching you...
    29 Apr 2003
    35 idle, 40 load, but my computer is currently in a desk (read: thick wood insulation) so they're a lot higher than they should be. That's probably MBM being wrong anyway...
  9. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    their a bit to high...what are youre case temps like?? and most importantly ventilation??
    i ussually get about 27-36idle (depending on the season) and have had a max of 42 on my tbred sofar....
  10. Carbon
    Carbon Banned
    8 Jan 2003
    xp2000+ 37Degrees (right now)
    System 32degrees (right now)
    Coolermaster X-dream @ 3000 RPM
    2 front intake fans - 80mm
    top exhaust - 80mm
    rear exhaust - 80mm
    2 fans on psu
    Soon to be buying Swiftech MCX-462+ and maybe 2500 barton :D
  11. severedhead
    severedhead What's a Dremel?
    19 Dec 2002
    XP1700 @ 2375MHz
    35 idle, low 40s under heavy load.
    Swiftech MCX-462 and a big delta.
    Measured with MBM so give or take a bit.
  12. Mightybob
    5 Sep 2003
    okay, update. I was reading the temp from the bios. I just used tose parts to upgrade my current system today, and it now sits at 30 C idle. Dunno how i got 15 C, just wish i could get it again.
  13. Sid
    Sid Banned
    13 Mar 2002
    Do you live in Alaska mighty bob? You'd have to be a room of about 5C to get those temps. :brrr:
    Edit: I see you got in your post while I was typing :) Still...your room would have to be pretty damn cold for those temps. I suspect dodgy motherboard readings.
  14. Mightybob
    5 Sep 2003
    nope, New Zealand :D
  15. Tim S
    Tim S OG
    8 Nov 2001
    webtemp owns j00! :p
    Barton 2500+ @ ~2.31ghz 1.775v full load 24/7, no motherboard heatsinking as yet, so temps are still a tad high :)
  16. MaSHim0t0
    8 Sep 2003
    I got the ANTEC 1040BII with A7V266-C
    Two fans in front, two in rear. My Volcano 9 is running at 3/4 speed of 1300-4800
    And as i said, I'm getting now
    50c on my cpu (XP 2000+)
    26c on MB
    28c on HD
    That's just regular IDLE. When playing games my CPU Temp jumpts to 53c
    I cleaned up my case (Wires in good position, no dust, etc..)
    Are my temps normal? They seem 10c higher than you guys
    BTW I never put in thermal paste.... would that help?
  17. Carbon
    Carbon Banned
    8 Jan 2003
    ARE YOU MAD :eeek:
    yes it would help ;) Artic silver 3 is what i use
  18. Hippo
    7 Mar 2003
    That has to be a contender for a quote in someones sig lol
  19. MaSHim0t0
    8 Sep 2003
    haha whoops, i never knew what the paste did, though it was like glue to help hold the cooler :duh:
    well put in the paste, thankfully i didn't throw it away. :wallbash:
    Anyways at 4800 RPM my idle is going 47c ugh... anyways to lower it more? I'm surpised I'm not getting 43.
    I also have the ducting mod... and it aint helping.
  20. ndtinker
    ndtinker Car Washoholic
    23 Sep 2002
    Mine runs about 38 to 42 between idle and load. It's an XP 2500 OC'd to 2.4ghz on water. It's a Swiftie MCW5000 block and the CPU's at 1.85v, if anyone's wondering.
