Cooling Where can I get 90degree 1/4bsp thread to 3/8ths barb fittings??
Discussion in 'Hardware' started by samcat, 13 Jan 2003.
  1. samcat
    samcat What's a Dremel?
    11 Nov 2002
    AS the title says.
    Where can I get 1/4bsp thread to 3/8ths barb fittings that have a 90 degree bend in them just after the thread...
    its for my reservoir and cpu W/B.. Will make it all fit in a LOT tidier.
    Have had a hunt through thorite's website with no luck.
    If you can find it (UK or people who can deliver to the uk) then I will be REALLY grateful :)
    Cya,
    Sam C
  2. samcat
    11 Nov 2002
    Oh, Doesnt matter if its plastic/brass/nickel plated or ???
    Cya,
    Sam C
  3. Haddy
    Haddy World Domination
    22 Jan 2002
  4. samcat
    11 Nov 2002
    Nope,
    Spent about 2 hours having a look for em on those sites. They have straight through ones but NO elbow ones :(
    I have added some new sites to the sticky, at the bottom. Worth a look but still no luck on the fittings I am after.
    May have to get on the lathe and make one or two :eek:
    Cya,
    Sam C
  5. Haddy
    22 Jan 2002
    Ah ok....well ill tkae a look later...shouldnt be that big of a deal....
  6. samcat
    11 Nov 2002
    Any luck haddy?
    I had another look last night, and still couldnt find what I was looking for :(
    Cya,
    Sam C
  7. Haddy
    22 Jan 2002
  8. samcat
    11 Nov 2002
    Certanly looks it... The thread end needs to be 1/4BSP (so about 1/2" OD) and the barb needs to be 3/8
    :D
    Sorted.
    Sam C
  9. Haddy
    22 Jan 2002
    Arg well ill keep searching...cant find anything....if u see any products that have them contact the manufacturer and see where they get them...:wallbash:
  10. PhiDeltCraiger
    PhiDeltCraiger What's a Dremel?
    13 Jul 2002
    Why don't you buy a 90 degree angle fitting with a male end and a female end. and Just screw in your regular barb fitting.
