Im after some mesh to go on the front of my case, local car parts place doesn't have it :/ gonna check B&Q later see if they do, anyone know where i can get some mesh? pref small holes but im not picky atm. Thanks 'doc
Mnpctech in america sells hexagonal and round mesh. You can get some from WizD but its a little steep!
thanks guys, quick reply! I only want a small section of mesh tbh, and that on kustom pc's is expensive i have sent an e-mail to http://www.finemeshmetals.co.uk/ they are only about 4 mile from me, hope they have some off cuts also i can't seem to find the mesh on pug's site :/ i may be being slow thou. thanks 'doc
just went they didn't have any, might check the warehouse one, do you know what the mesh is like from ther? thanks darv, i only need about a foot so £6.99 isn't too bad. 'doc
Halfords sell mesh. its for grills on the front of some of those nasty bodykits buy. You might have to buy a big section of mesh but i think it is quite cheap. Buzz
B&Q sell the same sort of mesh just cheeper, also you can buy sqaure foot of mesh from motor spares places etc, thats used for making new curves, for filling.
Halfords sell something called aluminium rust repair mesh.. it looks reallly really nice.. and has a kind of hexagonal design in it.. its only about £1.99 for a sheet as well...
Argos selling the computer table (£20) which is made from the same thing as above but much more ~ 4 times , just require some cutting work
my brother works at argos, 10% discount, don't need more then 20cm square thou tbh. Thanks for the find. 'doc EDIT Thanks! I will have to go and have a look asap, how tight is the mesh? 'doc^2
