Where do you find those little light pipe's for use after you stealth your drives? Or could you use a thicker fiber optic thread? Where would you go about buying any of these things? I'm looking for something relatively small, but the fiber optics I have are a little *too* small for my liking. Thanks!
i think you can buy audio fiberoptic cable.. its thicker than normal network fiber. just strip the black part away and stick it through, then trim off the rest.
If you had a bit of lexan lying around you could make one, no? If one edge is next to the led and the other edge faces outward... Just a thought.
