Motherboards Which AM3+ chipset?
Discussion in 'Hardware' started by Duffer, 6 Aug 2011.
  1. Duffer
    Duffer What's a Dremel?
    8 Dec 2010
    When bulldozer is released, i'm planning to commit herracy and rebuild my machine with Phenom ii. Can someone please give me a breakdown of the different AM3+ chipsets?
    I'm not worried about SLI/Crossfire etc, but need SATA 3, and would like USB 3. Would an 8xx series chipset be ok? What are the advantages of a 9xx series over the 8xx?
    Finally, if i am to upgrade to Bulldozer further down the line, which chipset would be most appropriate?
    Thanks in advance.
  2. jakobfrimmel
    jakobfrimmel What's a Dremel?
    2 Jan 2011
    well the 9xx chipse'st will definatly work for Bulldozer and the 8xx some will work and some wont... Personally i would go get a 9xx mobo because its better down the line and will give me a piece of mind if i were to upgrade...
  3. padrejones2001
    padrejones2001 Puppy Love
    17 Jun 2004
    There's only one true AM3+ chipset, and that's that 9XX series. The 8XX series boards that support AM3+ only do so because they have a modified BIOS, not because they were meant to support it to begin with. The 9XX boards also use a different system for power regulation, so if you're planning on overclocking, the 8XX boards may not take kindly to it. The 9XX chipset also features a faster HyperTransport, 3.1 vs 3.0.
    As for a breakdown of the chipset, it goes like this:
    Chipsets with no designation do not supposrt Crosfire or SLI.
    G chipsets have onboard graphics, typically featuring a PCI-e x16 slot.
    M chipsets have onboard graphics, typically featuring a PCI-e x16 slot. These are designed for mobile processors
    GX chipsets have onboard graphics, typically featuring a PCI-e x16 slot. Supports Crossfire by also utilizing onboard graphics.
    X chipsets also have PCI-e x16 slots, but typically feature two of them. Supports Crossfire.
    FX chipsets also have PCI-e x16 slots, but typically feature four of them. Supports Crossfire. Also the only chipset that supports quad graphics.
  4. Duffer
    8 Dec 2010
    OK, thanks for the info, chaps. So it looks like i'm after a good old fasioned 9xx series. Any recomendations? I'd like to spend below £100 idealy...
    Edit:
    At this stage, is it possible to tell which ones will and which won't? Or will we have to wait until they've been tested?
  5. padrejones2001
    17 Jun 2004
    In the sub-$100 category, this would be my recommendation. Link.
  6. meandmymouth
    meandmymouth Multimodder
    15 Sep 2009
    I'd agree here, good board with plenty of features for decent money.
  7. OCJunkie
    OCJunkie OC your Dremel too
    19 Apr 2011
    This. If you're buying a brand new AMD board there's no reason to go with an old 8xx chipset.
