Im planning on getting water cooling soon and i know exacly what im getting, but i dont know what fans to use on the radiator. Im getting the ThermoChill PA120.3 http://www.thermochill.com/pa1203.php and i have 4 spare 120mm fans http://i218.photobucket.com/albums/cc197/Harrybo17/DSCN0301.jpg 2x Silverstone that came with the case 2x Scythe that came with my heatsink. They both read 12volts the silverstone one is 0.07 amps and the Scythe is 0.18 amps which ones would produce the most air flow and i will use both of them and the 3rd i will just use one of the others. Thanks PS. what do you think to my new case http://i218.photobucket.com/albums/cc197/Harrybo17/DSCN0300.jpg
I'm guessing the Scythes are stronger since they require more power. I really wouldn't mix different speed fans on the rad if you can help it. There's a wealth of info around the net on tested fans that work well with that rad. Look here. Very long lengthy thread about many popular fans tested for those rads in particular. I personally use the Zalman ZM-F3's. Great for high speed and for quietness if ya need it. If not, google around.
