Graphics Which graphics to replace Nvidia 6600?
Discussion in 'Hardware' started by Iskador, 21 Feb 2010.
  1. Iskador
    Iskador What's a Dremel?
    21 Feb 2010
    My PC is a little old now (specs below) I've been recently getting up to date with all the new hardware available (mostly reading Custom PC). It has all been very confusing to say the least.
    My intention is to build from scratch as that is what I did with my current one.
    I have already purchased Windows 7, a OCUK Mod Xstream 600w psu, Antec P183 case and two extra fans: sharkoon slient eagle. I'm just about there with the funds to purchase the next bits - Intel i5 750, gigabyte m/board, 4gb ram, dvd rom. But the graphics card options are really confusing. Custom PC recommends a GTX260 for my budget £130 ish, but I cannot find anywhere that has them in stock. My second option was a ATI 4870, but can't find those, nor the 4890's. I see ATI have released new DX11 cards but the reviews are confusing as they speak for 22" plus monitors.
    It is my intension for the forseeable future to continue using my 19" Viewsonic VP920.
    What are my alternatives?
    OS: Windows XP SP3
    M/board: Gigabyte GA7n400V Pro
    CPU: Athlon XP 2200+
    RAM: DDR 1536mb
    Graphics: Nvidia 6600 256mb Turbo
    HD: can't remember
    DVD + CD: Lite on
    PSU: 400W something or other
    Case: Overclockers Typhoon
    Monitor: Viewsonic VP920 19"
  2. Elton
    23 Jan 2009
    Go for the HD5770, GTX260s are obscenely expensive and the HD4870 is a bit power hungry.
  3. llamafur
    llamafur WaterCooled fool
    27 Jul 2009
    The 5750 is also a good card. My friend got one and was content with its performance.
  4. azrael-
    azrael- I'm special...
    18 May 2008
    ^^ What he said.
  5. sHORNY
    sHORNY What's a Dremel?
    10 Feb 2010
    its fecking awesome :)
  6. shah
    shah Minimodder
    29 Jan 2010
    I would suggest a HD5770. I am using one and pleased with it. One problem ATI is so rubbish at their drivers. Still have problems when i browse. (the cursor will have very big font and some times grey screens). Games run very fine though. See the link below:
    http://www.overclockers.co.uk/showproduct.php?prodid=GX-222-SP.
  7. GoodBytes
    20 Jan 2007
    GTX 260 is hard to find to it's low production, as manufacture wait for or produces the coming up Geforce based on the Fermi architecture.
    I'll be surprised that when it's release it will fit your budget. You are better off with ATI 5000 series for now.
    If you have an old HDD (SATA1 or IDE), I would recommend a new one. The HDD (even a new one) will be the main cause of crawling your computer down (it wont' affect performance as is.. it's just that it will be slow to open program, save large project, load games, start windows, and so on.. anything that uses the HDD). Newer 7200RPM HDD are faster than the older IDE HDD's, and is welcomed. The ideal solution would be a SSD, but in my opinion it really not the time to even think about one. Way to expensive, and their capacity (30, 60, 80GB) is a joke for today, unless you are willing to pay one that might cost just as much as the rest of your computer.
  8. Iskador
    21 Feb 2010
    Thats very useful. Thanks for the advise. I hadn't considered the power consumption of the graphics card and the 5770 seems about my budget range. I can imagine this card is going to be astonishing compared to my 6600. My last new game was Doom 3 and this pc has trouble playing that at high settings.
    I will have to buy a new DVD-rom drive and hard drive. both are currently IDE. Back in 2006 when I last upgraded the dvd writers were £200 or so and I was just looking on overclockers uk and theyare now £20, amasing!. For the hard drive, the solid state drives look poor value for money. I was looking at Samsung F3 which seems to have good reviews.
  9. GoodBytes
    20 Jan 2007
    The jump for a 6600 to a 8800GT is HUGE! Now with the GTX 260 it even bigger, and again bigger with the ATI 5000 series.
    Be prepared to play your favorite, latest games at max max setting at 1920x1200 (16:10 - 24inch monitor) screen resolution without any trouble.
  10. rollo
    rollo Modder
    16 May 2008
    main dif is if you want an easy driver install vs performance
    260 if you can get it will still beat 5770 5750 ect. And it has much better drivers.
    no competion for 5850 though so you got put up with ATI crap drivers
    Nvidia pro drivers
    ATI crap drivers
  11. adam_bagpuss
    24 Apr 2009
    whats wrong with ATI drivers ?
    mine work just fine never had an issue with them for my 4870 and had my pc over a year
  12. Bloodburgers
    Bloodburgers Minimodder
    30 Apr 2009
    I know the majority of the thread is saying bout the gpu however something i noticed is that you are looking to get a new dvd drive. why i see u already have one. i am sure there is a explanation but no need buying new one if you dont need one.
  13. M7ck
    M7ck Ⓜod Ⓜaster
    28 Mar 2009
    Perhaps changing an ide for a sata one? Makes for a much tidier build.
  14. Bloodburgers
    30 Apr 2009
    as i said probably a good explanation but just wanted to potentially save him a few spondools
