Storage Which HDD?
Discussion in 'Hardware' started by MrDomRocks, 12 Nov 2012.
  1. MrDomRocks
    MrDomRocks Modder
    5 Sep 2011
    Hey guys, Ok a little background for the HDD's use. It will exclusively be used for Video Recording/Editing. I have a 1tb drive currently but it gets full rather quickly. I am wanting to expand my storage.
    My current drive is a Sata 3, and am considering Raiding my existing HDD with a new one.
    What I wonder which HDD is the best. Was thinking a WD Black 2tb+
  2. docodine
    docodine killed a guy once
    10 Feb 2007
    WD Black is kind of pricey, but if you feel you need it, it's a good hard drive.
    I only buy low RPM drives for storage now, less noise and everything important is on an SSD anyway.
  3. MrDomRocks
    MrDomRocks Modder
    5 Sep 2011
    I am after reliable read/write speeds, noise is an issue for me to be honest.
    This will be part of a large order. Need to replace my current headset as the Mic has died. two months into owning it.
  4. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    You're going to need at least three new drives for RAID5. Or were you thinking of JBOD?
  5. Pookeyhead
    30 Jan 2004
    He was thinking of RAIDing new drives with his existing one, so he'll need 2 drives for RAID5. He may be using 1 or 0 though. He didn't say WHY he was thinking of RAID. It may be speed he's after, or mirroring.
  6. mm vr
    18 Nov 2007
    Ah... But he was looking for 2TB drives, while the drive he already has is 1TB. That won't work very well.
  7. Pookeyhead
    30 Jan 2004
    You're right. If he uses his 1TB then the 2TB drives will only be using 1TB of their capacity.
    YEHBABY likes this.
  8. MrDomRocks
    MrDomRocks Modder
    5 Sep 2011
    To be honest it was ease of access waiting to a single drive rather than multiple drives.
    To raid the two drives need to be the same capacity?
  9. BennieboyUK
    BennieboyUK CPC Folder of the Month Sep 2011
    24 Nov 2010
    They dont, but if you have different sizes, it will only use the lowest size, unless you use JBOD.
    Also if you buy the super fast black drive and pair it with a slower disk, the faster drive will only perform at the slower speed.
  10. MrDomRocks
    MrDomRocks Modder
    5 Sep 2011
    Ok, I will simply use my current drive for static storage and my new drive for video.
