which memory?
Discussion in 'Hardware' started by Whitlog, 14 Nov 2006.
  1. Whitlog
    Whitlog What's a Dremel?
    26 Jul 2004
    i have a AMD athlon 64 3500+ with a gigabyte k8nsnxp 939 motherboard
    i have 2 sticks of 512 PC3200 (200mhx) corair memory.
    i want to get more memory but iam not sure what i could buy tht would work, and if you have to balance the memory or if i buy a stick of 1 gb will it efect stuff in a bad way coz of the memory i already have
    Thanks for info
  2. Kevin_G
    Kevin_G What's a Dremel?
    9 Nov 2006
    Memory is best installed in pairs with your system, so getting two 512 MB DIMMs would be preferable to getting just one 1 GB DIMM. Stick with PC3200 speed DIMMs like you already have installed for best performance.
  3. Whitlog
    26 Jul 2004
    cheers for the info
