Displays Which Monitor
Discussion in 'Hardware' started by Kronos, 22 Feb 2010.
  1. Kronos
    Kronos Multimodder
    6 Nov 2009
  2. Krikkit
    21 Jan 2003
    The ebuyer link is an LCDTV, I'd bin that for a start. You're paying for hardware in there that you won't use -> quality is less than a similarily priced monitor.
    What are your priorities? Size? Pixels? Any thoughts on aspect ratio?
  3. Kronos
    Kronos Multimodder
    6 Nov 2009
    Priorites? Hadn't given it much thought. Size? as big as I can gat and I think wide screen.I can probably push my budget to £400. So looking for suggestions in light of the increase budget.
    Thanks.
  4. azrael-
    azrael- I'm special...
    18 May 2008
    Your priorities should be image quality first and size second. Remember you have to look at the damned thing for a long time and size pretty quickly becomes unimportant if you can't stand looking at the screen.
    BTW, the LG M2794DP at Ebuyer isn't an LCD tv as such. It's a monitor with a tuner. There's a subtle difference. :)
    Personally I'd not buy any of the monitors listed. I'd suggest the Dell U2410, but that's about £450.
  5. Kronos
    Kronos Multimodder
    6 Nov 2009
    I am looking for something bigger than 24". thanks.
  6. DK63
    DK63 Resident magpie
    8 Sep 2009
  7. 13eightyfour
    13eightyfour Formerly Titanium Angel
    9 Sep 2003
    Unless your going to get the new 27" ips dell, or a dell 3008 (both of which are well over budget) i dont see the point in getting a monitor bigger than 24", all the affordable 27/30" monitors only have the same res as a 24".
  8. Kronos
    Kronos Multimodder
    6 Nov 2009
    After much research and heeding many suggestions and finding one for £370 I have decided to go for the Dell U2410 UltraSharp 24".
    Thanks all.
  9. azrael-
    18 May 2008
    Very good choice! That's one decision you won't regret! :)
  10. onthejazz
    onthejazz What's a Dremel?
    17 Feb 2010
    Where is the cheapest place to buy this dell monitor?
  11. Gulliver
    Gulliver Virtutem petamus
    8 Dec 2009
    Hi Kronos...
    If this price includes VAT and UK delivery, where did you find it ?
    Unless I've missed something, cheapest UK price delivered I can find is £413 from
    http://www.pcbuyit.co.uk/product_info.php?manufacturers_id=&products_id=822
    I also want a 16:10 screen and am planning on the Dell U2410, but as part of your research, did you find any other decent 1920x1200 screens at a similar (or lower) price?
    Thanks
  12. Kronos
    Kronos Multimodder
    6 Nov 2009
  13. Gulliver
    8 Dec 2009
    If you've recently bought a U2410 and are unaware of possible 'dithering' artifacts, perhaps you should see ....
    http://www.tftcentral.co.uk/news_archive/19.htm#dell_firmware
    ...read through to 'More info' at the bottom, and have a look at the numerous posts under ..... Dell Support Forms Thread.
    Sorry to be a spoilsport.
  14. Kronos
    Kronos Multimodder
    6 Nov 2009
    Foutunately I have the AO1 edition, so not a problem.
  15. Gulliver
    8 Dec 2009
    That's good - bet you're relieved !
    BTW - In my recent post, yes, I was asking about other 24" screens.
    There are indeed quite a few 16:10s about, but unless you do a specific search on 24"+16:10 - or similar, you have to trawl through many more 16:9s before you find a half-decent 16:10.
    Did you consider any 24" 16:10 alternatives to the U2410?
    Pity about the HP LP2475w, it gets a very good review in TFT Central and pricewise it's now close to the U2410, but I read that some units have issues with hum/tinting/eyestrain when working with text. And it hasn't the zero faulty pixel policy that the Dell has.
  16. Kronos
    Kronos Multimodder
    6 Nov 2009
    Apart from the HP LP2475w I looked at the LG W2452TX but couldn't find many reviews.
    But very happy with the dell. Paid 390 quid but worth it.
  17. Gulliver
    8 Dec 2009
    Thanks for the info on the LG W2452TX and will investigate but, as you say, the U2410 is a good screen.
