Displays Which monitor?
Discussion in 'Hardware' started by Ratchet219, 9 Sep 2011.
  1. Ratchet219
    Ratchet219 What's a Dremel?
    9 Aug 2011
    So I have been asked in school to make a power point presentation on monitor up to $400 and presented in class. On behalf of which monitor should I speak? Very simple question to you guys. Thank you all!
  2. MightyBenihana
    MightyBenihana Do or do not, there is no try
    8 Sep 2011
    Dell 2412m falls in at $399.99 on their website (Discounts available for those willing to try their hand at haggling).
    Talking point suggestions:
    16:10 ratio (better than 16:9? When and why?)
    IPS (is it needed, does it affect your usage?)
    Matte vs Glossy finish (preferences and why)
    Decent compromise on specs for price?
    Image quality vs TN or PVA panels.
    Quality of warranty included in price - does this affect peoples decision when buying?
    Is the response time adequate for those that want to game as well as those that need to use it for colour orientated programs (I.E. Photoshop, etc)
    This is a newly released monitor so plenty of people are having a say about it on Hardforum right now.
    I would have a look there for some more inspiration if you need it too.
    Good Luck
  3. Elton
    23 Jan 2009
    Dell U2410 or HP ZR24W. They're fantastic 16:10 monitors. Wish I could do that.
  4. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    Fixed for you
  5. Elton
    23 Jan 2009
    I'd say the Lp2475W as well, but that doesn't seem to exist.
    The ZR24W is not a bad monitor by any means though.
  6. The_Beast
    21 Apr 2007
    No it's not, I think it's the exact same panel just different manufactures/logos. I guess I have a bias toward the U2410
  7. Picarro
    Picarro What's a Dremel?
    9 Jun 2009
    The Dell U2410 is the best monitor in that price range
  8. Elton
    23 Jan 2009
    The Dell is a fantastic monitor there's no denying that, but I'm quite sure the ZR24W can be had for slightly cheaper.
    Then again, whatever really. The Dell by far is the only H-IPS panel I'd buy outside of the NECs.
  9. Ratchet219
    9 Aug 2011
    Dell u2410 is $499. I need something for $400 max. Thanks
  10. healthhazad
    healthhazad What's a Dremel?
    5 Aug 2011
    You could always just Google and do it yourself ;-) usually the point of homework lol
    I'm only teasing...
