Other Which Newsletter software? Please help
Discussion in 'Software' started by Neoki, 27 Nov 2012.
  1. Neoki
    Neoki Minimodder
    26 Oct 2004
    Hello,
    I am looking for software that will allow mass mailing to a customer list and allows tracking.
    So far I have seen groupmail and Sendblaster.
    Any one used software of this sort?
  2. halfinched
    halfinched What's a Dremel?
    19 Jul 2010
    I've used Sendblaster and found it to be simple and effective. Only problem with html mails is that they fake the address header so some email packages automatically filter to spam. There are so many different mail servers / filters / email packages it is almost impossible to stop this happening.
    I believe it should also be possible to get outlook or similar to act as a newsletter mailer (this will stop the faking of the mail header as it will come direct from your address, you can then schedule it to run when you are out / at night) but it depends on the size of your mail out. You will also need to consider a specialist bulkmail smtp server as your normal isp might block you if you start sending large quantity newsletters via their server.
    I know sendblaster will sell you this service but you might also consider an email marketing company http://www.ecircle.com/ (i almost used them - seemed like nice people but then the project didn't happen).
  3. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
